Old 04-14-2005, 04:26 PM   #1
AirMale
AirMale's Avatar
Pics of some trucks getting back halved
I stopped by a friends shop and he was in the process of finishing up some ladder bar set ups on 2 pre-80's swb trucks. Just thought you guys might want to see them.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 04-14-2005, 04:51 PM   #2
C-10volvo
C-10volvo's Avatar
how come everyone has a lift but me
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 04-14-2005, 07:49 PM   #3
bigblock73
yeller
bigblock73's Avatar
I don't have a lift either....and MAN, those are two mean looking trucks! What kind of powerplants do they have??
bigblock73 is offline   Reply With Quote
Old 04-14-2005, 08:14 PM   #4
AirMale
AirMale's Avatar
green one had a wicked 406cu and the blue one a mild 454cu
86 SWB 9.0 LITER
Old 04-14-2005, 11:12 PM   #5
fred 454
hey air can you get more pics of that blue truck,i like how it looks,thanks!
fred
fred 454 is offline   Reply With Quote
Old 04-14-2005, 11:36 PM   #6
low 84
low 84's Avatar
both look killer. very clean with no extra doo dads bolted on
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-14-2005, 11:43 PM   #7
stepside454
stepside454's Avatar
that 454 sprung a leak. looks really good, both trucks do, Id love to back half my stepside
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 04-15-2005, 08:00 AM   #8
bigarmzz
bigarmzz's Avatar
what size tires are on the black truck in the first pic?
looks like a nice set up (rims/tires)
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 04-15-2005, 09:04 AM   #9
Izzy
Trucker.
Izzy's Avatar
Damn that blue truck is sweet.
Izzy is offline   Reply With Quote
Old 04-15-2005, 10:27 AM   #10
Russell
Professional Grade
Russell's Avatar
Yeah, that 454 has got a pretty nasty coolant leak off the thermostat housing :P
All look good otherwise!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-15-2005, 06:15 PM   #11
AirMale
AirMale's Avatar
I wish I had taken some more pics for you guys but there will be other opportunities. Here's the only other shot I have of the tubs in the blue truck. I believe both trucks had 31X21x15's
86 SWB 9.0 LITER
Old 04-15-2005, 08:48 PM   #12
SS79chevy
i want to do that to my truck so bad eny know about what it would cost?
1979 chevy c10 short bed step side
BBC in the works
SS79chevy is offline   Reply With Quote
Old 04-16-2005, 12:27 AM   #13
87 Shortwide
That is alot like what I am after, just a little less overboard on the tire size...
Daily Driver: 1992 Blazer dropped on rallys
Project: 87 GMC shortwide, About to get a little boost
87 Shortwide is offline   Reply With Quote
Old 04-16-2005, 01:31 AM   #14
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Simply Mean.
Thanks for sharing.
Now how 'bout some pics of them tearing up the track.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-16-2005, 10:57 AM   #15
phantom dually
Project92 SWB stepside
phantom dually's Avatar
That si similar to the setup I am getting ready to put on. I have the dana 60 rear and the ladder bar setup. I am going to put a sizable notch in the frame which I got from suicidedoors and then box the frame from just under the cab back to the rear of the frame. I will be running a 335/30/20 tire in the rear on a 20x12 wheel. Plan to get started this weekend. Heres a pic of what I got tore apart.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 04-16-2005, 11:04 AM   #16
phantom dually
Looks like he had to turn his ladder bar crossmember up instead of down?? Originally these are meant to double as a drive shaft loop. I plan to do mine the same and run another strap off the crossmember to use it as such. Nice work BTW. Cant wait to get mine done.
Old 04-24-2005, 09:20 PM   #17
Col Clank
also wondering how much it would cost to do this????
Col Clank is offline   Reply With Quote
