Post Whore
![]() Join Date: Feb 2000
I have a chrome 4 speed shifter that I would like to use in my K20 but it would need to be bent a bit different. It is the stock chrome shifter out of an 89 Chevy truck. I know you would normally heat up a shifter to bend it. Can I bend this chrome shifter without screwing up the chrome? If so, how should I do it?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
bending it without heat will probably crack the chrome and make it spider web. heating it will turn it blue
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Seņor Member
I'm in need of doing the same thing... as well as lengthen. I'd imagine it's got some kind of heat treatment to it so the tooth on the end doesn't break off or bend. I am expecting it to require much hot to get it to happen. Then, I guess I'll send it off to get it rechromed or powdercoated... or maybe just Krylon.
Can you make the bend just under the shifter boot? (hmmm, might not have enough room). You might get away with cutting it & rewelding it, or maybe bending it at that location.Other than that Yukon you will run into plating problems. Usually when you heat chrome plating it will turn blue on you (chrome bike headers are a good example) However the make a product called "Blue Stuff" that will bring the chrome finish back again but I've never used it personally. Doug
Still drivin' a Rat Rod
Or you could heat the whole thing,and turn it all blue.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
they have the stuff to take the blue off of motorcycles pipes and thing ive never used it but it looks like it works
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
