Old 04-14-2005, 09:48 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
brake component question
i have a 67 short step that has been converted to discs....i have a 3/4 ton 72 BB and master cylinder and prop valve...i also have a 86 parts truck with the composite MC and thin BB....can i use the 86 stuff on my truck and get rid of the 3/4 ton 72 stuff? also...apparently parts stores dont sell prop valves.....will the 86 one work if i can get the lines off it? if i cant get the lines out will the 72 one work?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 04-14-2005, 09:49 PM   #2
67ChevyC10Stepside
also how do you get the rod to disconnect that goes to the pedal? i took the 4 bolts out on the 86 but cant get the damn rod apart..
Old 04-15-2005, 07:20 PM   #3
67ChevyC10Stepside
ttt
