Old 04-15-2005, 12:36 AM   #1
5150
C10 Club Tennessee
5150's Avatar
Where to cut front springs?
I borrowed this pic from RandyC10
Can anybody use photoshop or a paint program and tell me where to cut on these stock springs to get a 2 inch drop?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 04-15-2005, 08:39 AM   #2
72BLAZERDUDE
72BLAZERDUDE's Avatar
You have to cut exactly 1 coil from the spring because it sits in a pocket in the upper mount. So cut it directly below where the spring starts. I know it doesn't look like it will be 2 inches but trust me it will be at least that when they are mounted with the front end weight on them. Dont even be tempted to cut 2 coils. You will be buying another set if you do. Sorry I didnt have a photo available.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 04-15-2005, 11:37 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Do you cut the bottom or top?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-15-2005, 11:59 AM   #4
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
spring trimming
The bottom so it will sit flat, never the top! GOOD LUCK
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 04-15-2005, 02:05 PM   #5
72BLAZERDUDE
Should have said lower control arm. Must have been the muscle relaxers Forgot I had to turn the spring over to cut it.
Old 04-18-2005, 05:36 AM   #6
5150
C10 Club Tennessee
5150's Avatar
I've heard some people say that it gives 3-4 inches. I just want to make sure they are still usable after I cut them.
Bryan
www.gmtruckshow.com
Old 04-18-2005, 09:15 AM   #7
72BLAZERDUDE
This is a picture of my sons truck with 2 1/2 drop spindles and 1 coil cut out. I am guessing 4 to 5 inch drop total.
Old 04-18-2005, 01:42 PM   #8
5150
C10 Club Tennessee
5150's Avatar
Then 1 coil it is.
Bryan
www.gmtruckshow.com
