Old 04-15-2005, 01:25 AM   #1
gregbr
Senoir Member
gregbr's Avatar
doors hard to shut on 85 K10
Hi, We just got a 85 K10 and the doors are very hard to shut. Both sides have to be slammed. I checked and the doors are not lined up right, they are hanging about 3/8" low at the striker end.....but I cound not lift up on the doors any, so the bushings seem OK. Can the hinges be adjusted to even out the gap? If so, do I have to remove the fenders. Thanks!
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 04-15-2005, 01:38 AM   #2
Zilverado
Zilverado's Avatar
Well, it's been a while since I had my doors off, but if I remember correctly, "Yes" the hinges do have some adjustment. I believe the holes in the hinges are slotted.
If you try loosening the hinges, just remember that the top hinge has one bolt that is accessed from inside the cab, up behind the lower part of the dash. There is usually a rubber gromet in the hole, that has to be removed to get a socket in there.
I'm sure you'll get some other good advice, but that should give you some ideas.
Zilverado is offline   Reply With Quote
Old 04-15-2005, 10:04 AM   #3
useRc10
useRc10's Avatar
i need to adjust my passenger door...people getting in and out of the backseat always lean on it and it is hanging too low
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 04-15-2005, 10:56 AM   #4
TrainD5115
North Coast, baby!
TrainD5115's Avatar
If the doors are lower at the striker end than at the hinge end, there is most likely a worn hinge pin or the hinge itself has been rounded out by the pin. The hinges and the striker bolt can be moved. If your door is not hanging straight it won't close right no matter how much you move these. If you do have bad pins you will have to cut them with a dremel tool or something similar to get them out.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 04-15-2005, 11:05 AM   #5
86 GMG
your question has pretty much been answered so all i can say is good luck and if at all possible have a friend to help lift and hold door in place while you tighten bolts the doors are freakin heavy
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 04-15-2005, 12:30 PM   #6
Jonboy
Slots go on anything!
these doors also have a tendency to tear out at the hinges. If your hinges are tight, that may be your problem.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-15-2005, 02:26 PM   #7
gregbr
Senoir Member
gregbr's Avatar
Thanks, If the problem is the pins or bushings, shouldn't I be able to lift the door showing the slack in them? Because, I can't get any movement.
