Old 04-15-2005, 06:10 AM   #1
the baron
the baron's Avatar
Rod on a C10 base
Hi guys ,
I was thinking for years to build a "hot rod" ( Ford '32 or something similar ) , but after having looked for a suited frame , I never did find one , or they were a lot of €€€...
And as I really don't want to have something like others have , I then tought about the old C-10 long bed frame I still have in one of my boxes...
Hmmmmmm ! that should be something different...
So , I'm now conceiving a rod , to be build on my frame , with the 131.5 inches wheelbase...
and as I always have loved those 1930's "Indy specials" racing cars , there is the drawing ( here under )
the construction of the structure should be in wood , like in the good old days , but with a polyester body , set on a wooden one , very lightweight...
I've maybe found an old BB ( Mark Iv ) Chevy engine , it should be a good base to put on it...
the drawing :
there also two pic's of what it should look like , but slightly larger in size
So Guys , am I nuts or am I nuts ???
greetz
the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016
1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D.
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
Old 04-15-2005, 09:30 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Your nuts. I would still like to see you do it, though. Post pics when you are done!
Good luck with it.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-15-2005, 09:49 AM   #3
screwballl
Tonawanda 454
screwballl's Avatar
excellent drawings and excellent idea... now it is a matter of getting it all to work for you... yes you're nuts but i would still like to see something of this caliber done!
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
