Old 04-15-2005, 11:13 AM   #1
Rod
Any diff btwn 2wd and 4wd accelerator cable?
Are they different lenghts between these two type set ups? 2wd to 4wd 71-72 era accelerator cables... as in the cable from gas pedal to carb set ups.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-15-2005, 02:21 PM   #2
Rod
Why yes Rod there is. The 4wd drive one is a shorter lenght to the firewall.
Rod
or one of his splitting personalities.
Old 04-15-2005, 05:53 PM   #3
Rod
Gee Rod would you like a pic perhaps.....sure Rod, "I would".
Well here you go....note the top one is from a 72 2wd and the shorter one is from a 4wd 72 both are V eight application from a 4bbl carb.
Old 04-15-2005, 06:42 PM   #4
BobS
BobS's Avatar
OK Rod, put down the mouse and step away from the computer!
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 04-15-2005, 07:40 PM   #5
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
LOL...Thanks For the Info Rod(s)
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 04-16-2005, 12:12 AM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Hey Rod, have you been bunking with LudwigTheMad? LOL
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-16-2005, 05:00 AM   #7
Bob Moore
Rod - Is there a difference between small block and big block cables for 2wd?
Thanks - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 04-16-2005, 05:46 AM   #8
jamis
F.A.S.T. president
jamis's Avatar
sounds like theres other things starting to melt in Canada besides the snow.
Take a deep breath Rod.........LOL
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 04-16-2005, 08:59 AM   #9
Rod,could you ask yourself some more questions?I`ve learned something new from you guys.You make a great team.That is,as long as you don`t disagree.That must be tough.
Old 04-16-2005, 11:40 AM   #10
Rod
Well BOB, one of me went and looked at the 72 BB 402 2wd tow unit in the yard and it's on propane but the cable looked the same lenght on it as a 2wd v8 one as pictured above....
Ludwig.... I hear through the voices is into cloning experimentation now, either that or I think I got mad cow disease, or maybe it's Harley fever.
Old 04-17-2005, 04:49 AM   #11
4x4Poet
Maybe the 4wd throttle cables are shorter because 4x4 SBCs were back in the 6 cyl position, probably to clear the front pumpkin/axle under suspension compression?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 04-17-2005, 09:21 AM   #12
72swbcamo
Active Member
Accelerator cable
I have a 72 4X4 and it came with the long cable. When installed it loops around and created a circle. No problem it works fine. The truck is all apart now I'm doing a frame up, but when I put the cable back I'll install it just the way it was.
72swbcamo is offline   Reply With Quote
Old 04-17-2005, 12:11 PM   #13
kelsfine69
18 Till I Die
kelsfine69's Avatar
Is 72 the first year for throttle cables, because i have a 69 and it has a rod linkage. can I convert?
kelsfine69 is offline   Reply With Quote
Old 04-18-2005, 01:41 AM   #14
Rod
71 first year of cables
