Old 04-15-2005, 01:31 PM   #1
dtlilly
dtlilly's Avatar
Converting a 250 to power steering Question
I recently bought a PS pump and brackets to convert my 1972 with the 250 straight 6 motor.
Do I have everything I will need here?
I read that there was an alternator bracket associated with this type of swap, and I want to be sure I have all the available brackets to mount this to my engine.
dtlilly is offline   Reply With Quote
Old 04-15-2005, 02:55 PM   #2
shifty
Questionable
shifty's Avatar
Well, the F-shaped bracket at the bottom of both pictures is an alternator bracket.
You'll need a new pitman arm, power steering box and ragjoint.
It looks like the bracket you have on the pump currently is for a big block engine. The correct power steering bracket looks like this (see long alternator bracket; second hole is for PS pump assembly):
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-15-2005, 07:58 PM   #3
timmosams
Please post more progress pics as you move along. I am working on the same thing myself. I recently read a thread that had a very detailed article from Classic Trucks covering step by step instructions for such a swap.
timmosams is offline   Reply With Quote
Old 04-15-2005, 08:12 PM   #4
timmosams
http://67-72chevytrucks.com/vboard/s....php3?t=150751
Old 04-16-2005, 12:20 PM   #5
dtlilly
dtlilly's Avatar
Shifty, what is the upper slot in the bracket for?
Oh, duh! the PS pump!
Old 04-16-2005, 12:54 PM   #6
timmosams
here is the link to the article
http://www.customclassictrucks.com/techarticles/84378/
Old 04-16-2005, 01:22 PM   #7
dtlilly
dtlilly's Avatar
I have a steering box and arm coming from Teeitup. I have this pump and brackets, and I'm mostly interested in if these are the correct brackets for a 1972 C-30 with the 250 L-6. I guess I need to take some better pics.
Timmo, that article, although very interesting, is about a 60-66 truck, and it has a V8 engine.
Old 04-17-2005, 12:02 PM   #8
timmosams
True... but the swap from manual to power steering will be similar.
Old 04-18-2005, 12:40 AM   #9
shifty
Questionable
shifty's Avatar
All I can tell you is that the big ass long bracket you see for the alternator in my picture is supposed to be (at least one of) the correct brackets for PS setup with the L6 250. I might be able to help more if the parts one of the other boardmembers is sending makes its way this week. If it doesn, I hope to install PS by week-end.
Old 04-18-2005, 12:54 AM   #10
Rod
dtilly it looks like you have all the necessary brackets... pulley alignment is the issue now. You have dual waterpump pulley? and a single to add to the harmonic dual style? Thats one way its done.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-18-2005, 02:47 AM   #11
dtlilly
dtlilly's Avatar
Rod, I have a dual channel harmonic balancer and a single channel water pump pully.
