Old 06-10-2002, 11:33 AM   #1
johnymac
Question Questions about using adjustable proprtioning valve.
I have just converted my truck to power disc brakes. 1967 C10.
I have replaced the old proportioning value with a Wilwood adjustable one.
I am curious, took a wire off the old proportioning valve. Thinking this must be a low pressure valve. Not sure if I should try and buy some kind of a replacement. Figured I had better ask before I finish with the brake lines.
Has anyone replaced stock prop valve for and adjustable and found a solution for this ?
Any suggestions ?
Thanks much!!
johnymac is offline   Reply With Quote
Old 06-12-2002, 04:00 AM   #2
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Post
I think you have it almost right. Your wire off the old valve is for a brake warning light. Unless you specified to have this in the Wildwood valve - they didn't make provision for it. Chances are you would never see the warning come on from the original valve anyway. These were installed as "idiot light" devices for little old ladies who don't know how to check the master cylinder to see if the fluid is where it is supposed to be. Matter of fact, they probably don't even know what a master cylinder is! LOL
rico_bob
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 06-12-2002, 11:40 AM   #3
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
my master is full and the light will NOT GO OFF
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 06-12-2002, 12:14 PM   #4
johnymac
I have been calling around, looks like no one sells the value that would shut the low pressure light off, if they did have to wire into both fron and rear lines, so I think I will remove the light from the back of the dash.
Thanks to call that have replied to this.
