04-15-2005, 08:29 PM | #1 |
4x4 hub ????
I'm trying to get a 1/2 ton non-unlocking hub apart. Itook the cover off, pushed the collar in & got the snap ring & spring off. There is a spring loaded clip on the outer part of the hub, but that won't come out. Also, if I push the inner locking collar in & rotate it, I can push the flat clips outward, but that's it. What needs to be done to get this apart. My 4x4's are all K20's with locking hubs which come apart easily.......Thanks............Zoomy
04-15-2005, 11:35 PM | #2 |
What brand of hub is it?
04-15-2005, 11:38 PM | #3 |
Hub
I don't know what hub it is. It's a Dana 44 axle. The covers just had 4x4 cast into them...............Z
04-16-2005, 03:50 AM | #4 |
If it was like my 86 I had one H__l of a time. I had to use a small screwdriver to pry a locking pin out. Then when I was finished I could not get them back in. I went and got a set of warn hubs. You really had to look inside of them to find the last locking ring.
This is my best friend |
04-16-2005, 03:21 PM | #5 |
i dont believe he's talking about hubs at all, i believe he's talking about drive flanges, as in full time 4x4.
04-16-2005, 10:22 PM | #6 |
when i first got my truck it had those on it. they were silver/chrome circles whit a spring on the back. there were 2 snap rings on mine. i used some carb cleaner to blast the crusty greas out of there so i could find them. then i used a small screw driver to take that little gear out. if that is what your talking about
stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
04-17-2005, 11:23 AM | #7 |
DONT TRY THIS AT HOME!
how to get hubs apart
when all else fails dont forget the old adage...
there are few problems in life that cant be resolved with the proper application of high explosives |
