04-15-2005, 11:06 PM | #1 |
Driveshaft?
How do you remove the driveshaft from the tranny? I've got a 2-piece, I don't know if all of them are like that or what. Anyway, I unhooked the shaft from the rear end and just figured it would slide forward, nope. theres a bushing/hanger/carrier or whatever you wanna call it right in the middle and I can't push it past that. There is a bolt on the end of the first shaft in between the 2 but whenever I try to turn it it just spins, is that how I remove it? Even if that is how, it don't quite understand how that will help me...
Help ASAP. Thanks.
Ben 84 C10 Silverado 14 Silverado Z71 |
04-15-2005, 11:26 PM | #2 |
Designated Grumpy Old Man
Remove the bolts holding the center carrier bearing in place. That will allow the drive line to move forward enough to clear the yoke on the rear end. If you are going to just remove the rear half of the drive line mark both the front and rear halfs with something so you can slide the two together again in the same alignment. This helps with the drive line balance.
Any questions?
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
