Old 04-16-2005, 08:22 AM   #1
byrd
Union Electrician
byrd's Avatar
HELP!! with ignition
HI,
I have sbc 350 with hei ignition and keep burning up the hei module, like three in the past 5 months. Two were aftermarket and the third was a GM one and now I'm having trouble with it too!!
I checked everything that I know how to check and nothing. I know someone on here has had this problem before ,so please whoever you are please help me out on this. Thank you in advance, Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 04-16-2005, 08:29 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
How many volts are you getting to the HEI?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-16-2005, 09:06 AM   #3
byrd
Union Electrician
byrd's Avatar
12.4 or 12.7 can't remember. Randy
Zip:40272
Old 04-16-2005, 11:11 AM   #4
jhow66
jhow66's Avatar
How does it act when it goes out? Just quits running-will not start-sit awhile and then will restart?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-16-2005, 02:15 PM   #5
byrd
Union Electrician
byrd's Avatar
No just act like you turning off the key and backfires, till I get tired of it and replace the module, sometimes it does this for 15 or 20 minutes then acts right I'm stumped Randy
Zip:40272
Old 04-16-2005, 07:54 PM   #6
71swb4x4
71swb4x4's Avatar
I had a similar problem once. The wire to the starter had come off, and when it would swing just right it would ground out and the truck would die for a second, when it ungrounded itself it would run just fine.
I would recommend checking all of the gounds. make sure the engine has a good ground to the frame too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-16-2005, 10:05 PM   #7
jhow66
jhow66's Avatar
Have you checked the coil button in top of cap? My truck was doing me the same way (no backfire)-just quit like you turned the switch off. 1st time changed the module on the Interstate-started. 2nd time had it towed home and checked everything--found nothing and it started. 3th time had it towed and and pulled dist. and changed the pic-up-it started and no more problems since. (the pick-up moves with the vac. advance which was causing a internal short in the pick-up)
Old 04-16-2005, 10:31 PM   #8
byrd
Union Electrician
byrd's Avatar
what is the pick up exactly and is it under the dizzy? I like the way you think. I've talked to severals friends and a retired mech friend of mine and no one has mentioned that I will really look into this. How do you tell if this is happening, and wht needs to be done to fix it? I would assume local parts house for pick up? thanks in advanced Randy
Zip:40272
Old 04-16-2005, 11:01 PM   #9
jhow66
jhow66's Avatar
The pick-up is a electro-magnet that triggers the spark for the plugs. If you remove the rotor button you can see it. To replace it the dist. has to be removed and taken apart. Most of the time it is a problem that happens on and off as the tiny wires in the winding move .I will look as see if I can find you a photo of it.
Old 04-16-2005, 11:21 PM   #10
jhow66
jhow66's Avatar
Here's what it looks like:
Old 04-17-2005, 08:06 AM   #11
byrd
Union Electrician
byrd's Avatar
Thanks a bunch I'll look into this tomorrow. Randy
Zip:40272
