Old 04-16-2005, 11:00 AM   #1
chev406
Is it possible to change a 454 pan gasket in a 74 3/4 without pulling engine?
Anyone try doing a pan gasket on a 74! To me it looks like it might just be doable, not sure if the pan will clear the crank and cross member????
FYI, I can't get the search function to work at all! It kicks out the word "pan" when looking for pan gasket!
chev406 is offline   Reply With Quote
Old 04-16-2005, 11:02 AM   #2
stepside454
stepside454's Avatar
406 I think you can...may have to pull the bolts out of the mounts & jack it up a lil...if you do that dont forget to pull the dizzy so you dont cram it into the firewall
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 04-17-2005, 08:19 PM   #3
chev406
YUP! You was right, had to jack the engine up about 1"
