Old 04-16-2005, 04:54 PM   #1
mvpco
Lights flicker 1972 Chevy Truck
HI List!
I am stumped!
My lights(Headlights, dash etc) flicker when driving or parked. I can move the shifter (350, AUTO on the column) and when I put pressure on the gear shift it stops flickering, I can jiggle the shifter and see the lights flicker.
What I have done,
New Battery (still flickers)
New Alternator(still flickers)
I even disconnected the neutral safety switch and still flickers
also I noticed my dimmer switch does not have high beam, (I ordered one)
I have also ordered a new Headlight switch...
I checked the junction on the passenger side by battery and replaced that wire, (still flickers)
Any ideas?
Jeff Smith
Pensacola, FL
850-475-5030
mvpco is offline   Reply With Quote
Old 04-16-2005, 05:13 PM   #2
71-longbed
Its Magically Delicious
71-longbed's Avatar
HIgh beam switch if on the floor on the left hand side ..its seperate from the headlight switch .... check all your grounds .. alternator connections and such ...
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 04-16-2005, 11:21 PM   #3
HuggerCST
HuggerCST's Avatar
Bad ground. I had the same problem, but basically when you move the shifter, the cab gets it's ground through the linkage. I fixed mine by adding a ground strap between the cab and engine block.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 04-16-2005, 11:30 PM   #4
incoma
incoma's Avatar
I triple the other comments. Bad ground.
incoma is offline   Reply With Quote
Old 04-17-2005, 10:18 AM   #5
mvpco
Lights Flicker
Thanks! I will try and post back.
Jeff
Old 04-17-2005, 01:52 PM   #6
mvpco
Lights Flicker
I ran a ground from the firwall to engine block and all is working, I will try tonight when dark also
Thanks all!
Jeff
Old 04-17-2005, 10:03 PM   #7
mvpco
Lights flicker
Well I tried tonight and works great!!!!
Thanks all!
Jeff
Old 04-17-2005, 10:23 PM   #8
HuggerCST
HuggerCST's Avatar
Great! I'm glad it was a simple fix for you.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 04-18-2005, 04:51 AM   #9
mvpco
Lights flicker fixed
Yes, after I messed with it for over a month then broke down and ask about it here on the list, took about 4 hours to get a reply, then I tried it and it worked, simple only when the right answer is given.
Thanks again and GREAT Forum!!!!
Jeff
Old 04-18-2005, 11:30 AM   #10
farside847
farside847's Avatar
I have a similar problem, where on the firewall did you attach it?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 04-18-2005, 12:36 PM   #11
HuggerCST
HuggerCST's Avatar
I put mine on one of the studs for the brake booster. The factory ground straps attach to the firewall on each side of the engine, and run to a valve cover bolt on each head (v-8) if I'm not mistaken.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
