Smell that burnin' rubber
Cab mounts - part numbers?
I want to replace only the upper cushions of my 4 cab mounts and 2 rad mounts. GM-Parts-Direct lists the part numbers and descriptions below, but I'm not sure which ones I need, and if the ones I need are all the same. Any help is appreciated.
GM PART # 3909351 BODY MOUNT CUSHION PANEL TRUCK/SUBURBAN GM PART # 3951798 UPPER MOUNT CAB MOUNT GM PART # 3953135 LOWER MOUNT 2 WHEELDRIVE GM PART # 3957829 BODY MOUNT CUSHION REAR CAB MOUNTS |
I don't know the GM part numbers, but my local Chevy dealer parts dept wanted about $300 for all the bushings for my K10 burb. And that's just the rubber!
GMC Pauls, for one, sells rubber cab mounts. They had my burb mounts, again minus hardware, for $184 +shp. Still expensive, but not dealer gouging. Cab mounts cost much less. Here's theircab mount page.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
Thanks for the feedback 4X4. Ya, the 4 wheel drive kits are expensive. The GM-Parts-Direct cushions are reasonably cheap, so I think I may order 2 of each to see what I come up with.
