who has used different year master cylinders on their trucks?
I'd like a aluminum one with plastic resovior, for a hi-perf. look. Anyone ever done this? What booster did you use with it? Any mounting adaption problems?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
anybody????
#3 | |
Bloo
i didnt do anything fancy, but 1974 master cylinder with original booster on my 4x4
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
You should be able to verify the cylinder bore through your local parts house but my bet is a 88-up truck thru 91 burb mstr.cyl would be close in bore size & interchangability. For 4-wheel discs try a 81 trans-am or cadillac. If you find one that works let us know.
Progress = 0%
I'm planning on using one off a mid-80's S-10 blazer. It is aluminum, with a plastic reservoir. I'm not going to use a booster, so it should bolt right up. Some people will say it's too small for the big truck brakes, but a friend of mine has one off a Fiero on his '58 Nomad (with Chevelle calipers up front) and he says it stops just fine. If it ain't enough, i could always get one off a mid to late 80's chevy 1/2 ton truck. I think it'll work okay though.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
