Old 04-17-2005, 01:48 AM   #1
skokie
skokie's Avatar
Leaking Intake Manifold
I noticed this under my intake. Does this mean its leaking? I felt around under it and it didnt have any oil that I could feel.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 04-17-2005, 02:44 AM   #2
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Yup, looks like a front manifold leak. That will happen when the your engine is at speed because of existing oil pressure and oil being slung around under the manifold. Did you use the runner gasket, or plain RTV there?
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 04-17-2005, 04:42 PM   #3
skokie
skokie's Avatar
I used the ultra black rtv. I layed down a bead about as thick as a straw and let it sit for about 30 mins before I put the intake on. That may explain why I thought I had a rear seal leak. Its coming down the front and blowing down along the oil pan and getting to the tranny dust cover. Well I hope I am right. Also has anyone done this. Layed down a thin bead of rtv put on the rubber gasket and then layed down mpre rtv and put the intake on?
68 build thread
Old 04-17-2005, 04:54 PM   #4
Dean23
68cst_ss490
Dean23's Avatar
dont use rtv and agasket it wont seal. when you use rtv both surfaces must be spotless. clean off old rtv till you get to nice clean bare metal then use some brake clean on a rag and wiper both mounting surfaces clean. tehn splly the rtv and set the intake on and torque it down. another bonus is dont start it for 24-48 hours this gives the rtv a good chance to cure
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 04-17-2005, 06:37 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
Adding to what Dean said, inspect the sealant while it is still wet, looking for gaps. Properly applied, it should squeeze out in a uniform bead. After it's cured, you can trim the excess with a razor blade.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
