Old 04-17-2005, 02:07 AM   #1
StingRay
StingRay's Avatar
It's heart will beat again
Well after what seems like a long truckless winter my old GMC's heart will beat again. It had the front end destroyed by an ahole kid that thought he was the road warrior and a week later the camshaft lost a lobe and pretty much laid waste to my small block. After pulling the engine, tearing it down and sending the parts to the machine shop I was told it was due for just about everthing so that's what she got.
I had it bored 30 over and torque plate honed, line bored, decked and balanced. I used flat top hypereutectic pistons with coated skirts and pretty much new everthing else including a true roller chain, high volume pump and roller tiped rockers. It has a Z28 oil pan and windage tray from it's last rebuild 10 years ago that I had powder coated along with a stock set of valve covers and the timing cover. The heads are 194's that were gone through and treated to a 3 angle valve job. My old intake had suffered a bit of corrosion so instead of repairing it I threw on a new 2101 performer. The q-jet was professionally rebuilt 2 years ago but I refreshed it with new gaskets and a clean up. It has an HEI with an MSD blaster coil, crane adjustable vac advance and a MSD 6A box. All parts and brackets were cleaned and/or blasted and repainted and most fasteners replaced with stainless. I had my TH 350 rebuilt as well.
I hope to drop it in tomorrow and then I'll scab together a front clip till I can put my new body on it later this summer. For now I need it to work for it's keep around the acreage. Looking good will have to come a little later. The engine was real strong prior to failure even with about 90,000 miles on it so it should be a real strong performer all freshend up and with higher compression. Some day I hope to ditch the 194 heads and put on a set of L98 aluminum heads I have and then retire it from it's "working" life.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-17-2005, 02:49 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Looks sweeeeeet! Nice job!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-17-2005, 04:23 AM   #3
krue
Designated A-hole!
krue's Avatar
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-17-2005, 10:31 AM   #4
Paul72
Paul72's Avatar
Looking good.
What are the cam specs? What HP/TQ are you expecting?
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 04-17-2005, 01:00 PM   #5
Looks good. Getting them moving is great. They look good even when they look like a circus wagon of parts!
Old 04-18-2005, 12:04 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Gonna be a big difference when you get back on the road, I'm sure.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
