Old 06-10-2002, 05:23 PM   #1
mikep
Used to have a truck
mikep's Avatar
Could someone with a dyno program help me out here
I'm trying to figure out what rear end gears to get here and I'd like some help if possible by someone with a dyno program. I'm trying to figure out where my peak torque and HP are.
My engine is a 350 chevrolet . Its .030" over . I have a .030" head gasket, zero decked, 1/8" domed pistons,
72CC chamber 200 cc intake port world product sportsman II heads which gives me about 10.2:1 compression. 2.02 inatke valves and 1.6 exhaust
The cam specs are .494" lift intake and exhaust . 232 degrees intake duration 234 exhaust on 108 degree centers. Roller tip steel rockers.
Air Gap RPM Intake. port matched
800 CFM edelbrock EPS carburetor
1 1/2 primary headers with 3 inch mufflers
HEI with MSD module
Need anything else? Any help would be appreciated
No truck :-(
mikep is offline   Reply With Quote
Old 06-10-2002, 06:08 PM   #2
bigjimzlll
bigjimzlll's Avatar
first thing... .030 quench? thats too close...even for professional engine builders...lingenfeller says .045...most others say that never closer than .035.. have you checked valve clearence with the domed pistons?
DD2000 says max hp @6000 is 382....max torque @4500 is 392
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-10-2002, 06:21 PM   #3
mikep
mikep's Avatar
whoa
i need to do a better job of proofreading. That should be .060" gasket with zero deck. Thanks for the numbers. No problem on the valve clearance.
Mike
No truck :-(
