Old 04-17-2005, 01:15 PM   #1
aurorable
5 Lug or 6 Lug Disc Conversion?
What would be the choice among those on here between a 5 lug or 6 lug disc brake conversion. I have a 6 lug setup on my 70 GMC now. I'm trying to weigh all my options before digging into this project. If I change to 5 lug, then I would have to change the rear to look right. What to do
thanks, steve
aurorable is offline   Reply With Quote
Old 04-17-2005, 02:47 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I look at it like this, the 6 lug rotors are not common parts, you have to special order, and I wouldn't be suprised if it is only one company making them.
I'd go 5 lug.
Old 04-17-2005, 03:31 PM   #3
70short/step
70short/step's Avatar
It also depends on what wheels you want to run. There are so many more wheel styles to choose from in 5 lug. I went with 5 lug on my 70.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 04-17-2005, 04:10 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
5 lug on my 70 also.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 04-17-2005, 09:52 PM   #5
FirstGen
Just Don't Stop!
FirstGen's Avatar
I'd go 5 lug.
really is autozone/orielys hard to get parts from? seriously look at the "early disc brake swap" thread...
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 04-17-2005, 10:16 PM   #6
Kas68c10
Kas68c10's Avatar
changed the 68 to 5 lug for the wheeel syle choice...
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 04-18-2005, 04:36 AM   #7
FirstGen
Just Don't Stop!
FirstGen's Avatar
yeah that's exactly why I wanted to keep 6 lug...
TT LSA/6L90e/9"
Old 04-18-2005, 08:53 AM   #8
Kas68c10
Kas68c10's Avatar
Actually, I guess I did it for the pwr disc brakes setup...
Old 04-18-2005, 10:47 AM   #9
FirstGen
Just Don't Stop!
FirstGen's Avatar
really? obviously it would be just as easy to go power disc on a 5 lug compared to 6 lug disc. I choose not to use power brakes because of the cam in my truck, not alot of vaccume and I don't want to add a canister or pump or any of that junk...
TT LSA/6L90e/9"
Old 04-18-2005, 11:58 AM   #10
Kas68c10
Kas68c10's Avatar
donor truck was 5 lug
Old 04-18-2005, 06:45 PM   #11
Longhorn Man
Haven't looked for this thread yet...getting rerady to, but why would they carry 6 lug rotors? They were never offered on anything that would swap onto our rides.
Old 04-18-2005, 07:49 PM   #12
69 longhorn
I wouldnt think a 6 lug rotor would be common in most parts stores(order item maybe?) One good thing tho, is that those rotors were very thick on the old trucks......if you have a new set, you can turn em enough to do probabl 4 or 5 brake jobs. Thats a bunch of miles! L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-18-2005, 08:20 PM   #13
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
it all depends on what you want. i bought 6 lug rotors from ECE that will fit stock 5 lug spindles, they cost more but then you dont have to mess with an axel swap too. it keeps the 'original' look plus how many 6 lug disc trucks are out there??? also if you go 5 lug you have to get new wheels now where 6 lug you can get them later. but with 6 lug rotors you will have to pay more if they warp and you need new ones. pros and cons to each. it all depends on what you want.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 04-18-2005, 11:22 PM   #14
FirstGen
Just Don't Stop!
FirstGen's Avatar
Well they came on the 1990's 2500 series trucks. I used the spindle and newer ball joints to do the swap. All parts I used were from off the shelf stuff at AutoZone... any 1988-1998 spindle will work you just have to make sure it has the 1.25" rotors. Then go buy new 6 lug rotors if it didn't already have them...thread is in the FAQ section now...
TT LSA/6L90e/9"
Old 04-18-2005, 11:54 PM   #15
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I'd go to 5 lug,and swap to the later model calipers while you're at it.I have a 71,and the way they tell it at Oriellys/Autozone and NAPA is that that was a one year caliper,and brakeline,andthey can't get them.I did manage to find one at Carquest,and got it going again,but it's about due pads,and from my understandin I can use 73-87 calipers,and lines,and have a much easier time getting parts.
Correct me if I'm wrong on this one guys,this was what I was told by the manager of NAPA.Also seems the later model lines are about half price too.
Either way Power disc is hte only way to stop
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-19-2005, 06:19 AM   #16
Longhorn Man
yup, 1/2 ton 1971 is a one year set up.
Sucks trying to find obsolete stuff huh?
First gen...I'll have to go read that, this is the first I have heard of it.
Old 04-19-2005, 10:54 AM   #17
FirstGen
Just Don't Stop!
FirstGen's Avatar
longhorn man - http://67-72chevytrucks.com/vboard/s...d.php3?t=35042
the guy starts off kind shady like it was hard to tell if he really did the swap or not. Actually one of the part numbers he gives was wrong , but I actually did it and it was pretty simple. I posted pics of the results also.
Take care.
TT LSA/6L90e/9"
