Old 04-17-2005, 09:45 PM   #1
Rod
Rear sway bar pic for 4x4 3/4 ton and 1 ton 2wd
Thought I'd show what a rear sway bar and how it hooks up to a leaf spring lower spring bracket...it's a rare piece. The frame bracket little clips aren't shown...but they just hook to the bottom of the frame rail....almost look like the front sway bar style hanging bracket. There are brackets that mount to the bottom of leaf spring brackets...which the bar slides into rubber bushing in those brackets.
Got digging into a stash of parts I had.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-18-2005, 09:40 AM   #2
That`s factory?I did not know that.Thank you very much.
Old 04-18-2005, 09:41 AM   #3
1969 GMC
1969 GMC's Avatar
I must say I don't believe that is factory. But stranger things have happened.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-18-2005, 11:57 AM   #4
Rod
Well...factory yes...but from what is the question? It's all part of what fits what.
Old 04-18-2005, 12:00 PM   #5
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Factory rear sway bars were available on 73 and newer trucks.
I have mostly seen them on 1 ton Camper Specials.
I have never seen a factory installed on 67-72, but I haven't seen everything...
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 04-18-2005, 12:30 PM   #6
Rod
Well this came off a 64.
Old 04-18-2005, 12:56 PM   #7
BobS
BobS's Avatar
If you look in the service manuals you will see that rear sway bars were available on P30 Forward Control models, I'm looking for one if anyone happens to find one.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 04-18-2005, 01:29 PM   #8
Rod
And BobS got it right it came off a P30.
Old 04-18-2005, 07:03 PM   #9
Hey,trick question.Wah-wah-wah.I had one on my`78 Dually CamperSpecial.
Old 04-19-2005, 06:55 AM   #10
Rod
Good stuff...but is it the same width ..might be since its a dually. And how did it mount to the axle....the axle ubolt brackets are a different style.
Old 04-23-2005, 04:15 AM   #11
4x4Poet
If, on a 67-72 4x4, one uses 73up u-bolt plates (top of spring pack) with appropriate u-bolts (wrap under axle), would the 78 1 ton dually ubolt plates/brackets work to affix the ends of the 78 swaybar to the axle? Leaving only the fabbing of frame mounting brackets?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 04-23-2005, 06:48 AM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I almost had my hands on one of them...off a 68 P-30.
If I ever get the chance again, you'd better believe I'll grab it.
Old 04-23-2005, 07:45 AM   #13
Huck
Huck's Avatar
Nothing quite like a rare piece--and the older you get, every piece is rare!
Huck is offline   Reply With Quote
Old 04-23-2005, 07:48 AM   #14
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Talking Rear sway bar
Rod, I got one to it came off a 72 P30 Motor Home Chassis. That thing was a boat it had everything kitchen sink, bathroom, the works. It also had a weird brake system with a assist stuff on the frame. Does anyone make a urthane bushings for this set-up?
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 04-24-2005, 04:09 AM   #15
4x4Poet
Originally Posted by 67-72williso
...Does anyone make a urthane bushings for this set-up?
Wouldn't generic poly sway bar bushings work? Like from Energy Suspension:
End link bushings
Frame bushings
Am I the only one that got this?
Old 04-24-2005, 05:39 PM   #16
Rod
When you get into the rear diff that has the ten bolt wheel stud pattern your talking the H110 differential. Those diffs had an assist brake sysytem that had vacuum pods mounted to the frame rails on each side. There is one like that about 30 miles from me and about once a year I go see him...I'll try to rememeber to take pics next time I go there. Its a 72 (I think), but it is 1 ton dually 157 inch wheel base with 6.17 geared rear end ratio.
Old 04-25-2005, 12:56 AM   #17
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
This is a late 70's-80's dually rear sway bar that I put on my 70 GMC 3/4T.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 04-25-2005, 01:48 AM   #18
69 Short Fleet
Rod. Thanks for sharing, whats the dia. of that bar 1 1/8" ? (it does not look like a 1 1/4 from the pic) And (just to make things more complicated, LOL) were they available in different dia.? Like 7/8", 1 1/8", 1 1/4". Doug
69 Short Fleet is offline   Reply With Quote
Old 04-25-2005, 08:59 AM   #19
Brewski*
Brewski*'s Avatar
Has anyone used or seen these sway bars installed? They look like a great bolt on product fo our trucks. Suspension Connection
Brewski* is offline   Reply With Quote
Old 04-25-2005, 10:24 AM   #20
Rod
The sway bar I posted a pic of in the beginning of the thread is 1 inch.
Pickmup ..that sway bar you installed.....is it on a dually rear diff housing even though on a 3/4 ton? The bottom mounting purchase is what I am asking about or are they there on some diffs. Or did you have that welded on?
Old 04-25-2005, 11:49 AM   #21
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
The sway bar came off a 1 ton 2wd (but, same one is also on my 79 dually).
I put it on my 70 GMC 3/4T single wheel truck.
The rear brackets, under the diff bolt on and are held by the ubolts.
The frame brackets, at the front of the bar, are bed mounts off one of our truck frames...welded on.
Phone: 360-956-7170
Old 04-26-2005, 03:07 AM   #22
4x4Poet
Brewski, I'm leary of the *Fast, Easy "Bolt-On" installation* claim. The pic shows nothing, the sales pitch makes no mention of the fact that most 4x4 67-72s don't have swaybar mount locations on the frame or the axle/u-bolt plates, and Bolt-on is in both bold and italics. Makes me think of over-emphasized air quotes.
Old 04-26-2005, 12:04 PM   #23
Brewski*
Brewski*'s Avatar
4x4Poet: "I'm leary of the *Fast, Easy "Bolt-On" installation* claim also. Like you say the pic shows nothing, the sales pitch makes no mention of the fact that most 4x4 67-72s don't have swaybar mount locations on the frame or the axle. But these are HELLWIG products http://www.hellwigproducts.com/antis...tic4x4_gm.html which have been around forever and have been OEM on most Big Rigs and with 1 & 1/8" bars they should be rock solid in the corners. I have e-mailed HELLWIG directly and ask for the BOLT ON installation instructions. I will start another post when I get some.
Old 04-26-2005, 01:40 PM   #24
Brewski*
Brewski*'s Avatar
Here is how the Hellwig hooks up sounds pretty good?
front bar # 7431 mounts on crossmember we supply and arms on top of the
vehicles springs all mounting hardware is included in our kit, rear bar #
7413 in front of the axle with arms towards the front of the vehicle again
all mounting hardware is included in the kit as far as the suburban these
kits will not fit, we do not offer any kits for this year only 1973 and up
thanks Gilbert
----- Original Message -----
To: <customerservice@hellwigproducts.com>
Sent: Tuesday, April 26, 2005 9:08 AM
> Hello Hellwig,
> I am interested in your 67-72 K10 & K20 Pickup 7431 1-1/8" 7413 1-1/8"
"Bolt on" package. I do need to know how they bolt on as there are no stock
mounts for these year trucks. I also need to know if they fit on the K20 and
K10 Suburban of this era. If you can scan some instructions and send them to
me that would be fantastic. Or, they can be shipped to:
> SS CUSTOMSS
> 27541 Happy Terrace
> Rocky Mount, MO 65072
> Thanks,
> Bruce Kohen
> Owner
Old 04-27-2005, 10:22 AM   #25
Rod
thanks Gilbert
> Hello Hellwig,
> SS CUSTOMSS
> 27541 Happy Terrace
> Thanks,
> Bruce Kohen
> Owner
I read it that it does not fit the rear. But they have a front kit.
