Old 04-18-2005, 12:02 PM   #1
tnblazerk5
User #12137
tnblazerk5's Avatar
speedo bounces ?
why does the speedo needle in my truck bounce ? it needle bounces all the time . is the speedo itself wore out or is it the other end where it hooks to the trans ? or is it the cable ? or is it sumthing else ?
tnblazerk5 is offline   Reply With Quote
Old 04-18-2005, 12:20 PM   #2
chevyfarmer
chevyfarmer's Avatar
I would guess the cable. I have had "jumpers" like you are talking about and it was the cable that fixed it. I do not know what a worn out speedo would look like but maybe someone else can shed some light on that one.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 04-18-2005, 12:25 PM   #3
HuggerCST
HuggerCST's Avatar
Probably just the cable needing lube. Take it loose at the speedo end, pull out the inner cable, oil it up with either oil or white lube, and put it back together. Should fix your problem Robb!
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 04-18-2005, 12:26 PM   #4
tnblazerk5
User #12137
tnblazerk5's Avatar
ok on the cable and the worn out part i was takin about would be the back of the speedo where the cable goes in might be wobled out or does that happin ?
i just got the cable and it was used so yea it might be the cable lol you think if i added grafite<sp? to the cable it would help it any ?
Old 04-18-2005, 12:26 PM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
ok i can do that !!!!! thanks !!!!!!!
Old 04-18-2005, 01:40 PM   #6
Putter
More Cowbell....
Putter's Avatar
Hey TN, is your truck a manual (I think manual cables are shorter than autos...)? If so, I can send you a cable to use (or gauge if that is the issue). I just pulled mine out with the engine swap, and it did not bounce at all. I can send it with George to Pigeon Forge if you want it.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 04-18-2005, 01:58 PM   #7
tnblazerk5
User #12137
tnblazerk5's Avatar
its a 327/350 combo and i will have to lube up the cable thats there and see what happins then i can let ya know if i need any of that . thanks!!!!!
Old 04-18-2005, 02:06 PM   #8
71C/10
something else you may check if lubing the speedo cable is unsuccessful is the plastic gear on the transmission output shaft. if it has missing teeth it can definitely do as you are describing. the gear on my output shaft is currently m.i.a. this seems to be a fairly common problem once that gear begins to age. if the gear looks ok try taking the cluster out of the dash & running the speedo head with a drill. you can get a nice consistent rpm with a drill and watch for the bounce.
1971 C/10..650,000 miles & counting
71C/10 is offline   Reply With Quote
Old 04-18-2005, 03:31 PM   #9
shifty
Questionable
shifty's Avatar
I am actually having the same general problem. I see bounces when driving, but not with a drill hooked up to it. I have a '69 3spd in my '68 truck. I had to get a longer cable b/c the speedo gear is farther back on the truck. I lubed the hell out of my cable, still had the problem. Very strange. I'm just living with it for now, I am hoping to have a new tranny this week
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
