Old 04-18-2005, 03:07 PM   #1
Purs
Got Big Block?
Purs's Avatar
grinding upper control arm?
Is it safe to clearance (grind) the upper control arm to clear my new spindles? I got a set of McGhaughys 2.5" drop spindles from a board member, installed the new upper ball joints that came with them and I get some binding when I try turn the wheels. The are hitting pretty bad the top of the spindle. Anybody had to do this to clear there spindles? thanks.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 04-18-2005, 05:03 PM   #2
Frank_Zeller
Frank_Zeller's Avatar
I had to clearance the lower a-arms with 15x8 4.5 BS truck rallies with McGhaughys 2.5" 2 inch drop spring
The rim would catch the lower A rim when the full righ/left turn
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 04-18-2005, 07:25 PM   #3
Spoof
Spoof's Avatar
In the Bell tech installation instructions for their 2.5 drop spindles they indicate spots on your upper control arms which may be ground down to obtain clearance. I have to assume it is safe to do so if they'd put in in writing? Grind away
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 04-18-2005, 09:27 PM   #4
72MARIO
72MARIO's Avatar
I had to grinda little with My Western 2.5 Drop spindles. I only took less than 1/8" though.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-18-2005, 09:40 PM   #5
gashog
Active Member
gashog's Avatar
I had to grind about 3/16" in the contact area to clear my McGhaughys 2.5" drop spindles and have not had any problems, should be fine.
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z
gashog is offline   Reply With Quote
Old 04-18-2005, 09:44 PM   #6
Purs
Got Big Block?
Purs's Avatar
thanks for all the replies guys. Next question, do I have to disassemble everything to loosen the spindle from the top ball joint to gain access to grind on the UCA? I know about the proper removal from the lower ball joint, but it looks like to me the spring is held in by the crossmember, not the UCA. I hate to take everything apart. advice appreciated.
