WTB: 10 bolt or 12 bolt with 3.73's in Houston area
The gears in my 76' are too high for the 700r4 that was swapped in. Also, I just noticed that the rear end is leaking a little oil around the yoke. Rather than fix it and replace the gears, I figure it would be easier and cheaper to just replace the rear end. If anyone has one, send me a pm.
Thanks Last edited by Greenlee; 04-19-2005 at 02:44 PM. |
#2 | |
the pinion seal is easy to fix.....cost less than $10 ![]()
1987 350 TBI lowered 5/7 |
#3 | |
I've got a set of 3.73's that have about 500 miles on them. I changed to these from the factory 3.08's, then changed transmissions that had different overdrive ratios so i promptly took them back out. I'd take $50 for them. The tail bearing and shim is still on there so the pinion depth and set up should be close. Let me know
