Old 04-18-2005, 07:50 PM   #1
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
Difference between tilt & non-tilt linkage hookup?
I'm in the middle of replacing my non-tilt column with a correct truck tilt column. But, I notice that the original column has a gear position detent arm (by the shift arm) that the tilt column doesn't. Also, the original shift arm (where it connects to the linkage) comes out at 90 degrees to the column, while the tilt shift arm comes out at about 45 degree to column.
Does the tilt column have an internal detent system?
Does the shift arm on the tilt column come out at 45 degrees, or is mine bent?
Dual quad is offline   Reply With Quote
Old 04-18-2005, 08:33 PM   #2
krue
Designated A-hole!
krue's Avatar
The tilt column on the cab I just installed has internal detents. I bent mine while doing the cab swap, so I just bent it back to reach the linkage on the frame. Works great so I guess I didn't screw it up too bad.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-18-2005, 08:43 PM   #3
71swb4x4
71swb4x4's Avatar
What Krue said.
In order to take them out you have to bend the shift arm, so when you install it you have to bend it back.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-19-2005, 07:07 AM   #4
Dual quad
Dual quad's Avatar
Great, thanks for the feedback guys.
