04-18-2005, 09:35 PM | #1 |
Chevy Freak
Anyone need any frame parts?
I'm taking the rest of this truck to the scrap yard this weekend. I'm taking some more parts off of it (overloads, trailing arms, power steering, ac dash, etc.), but is there any other frame parts anyone would want before it goes bye bye? It's a 70 2wd longbed truck.
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
04-18-2005, 09:57 PM | #2 |
How are the rear cab mounts?
Thanks! Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt Came home from the hospital in it & mine ever since. 1966 Catalina Ventura 2-door fastback 389/TH400 |
04-18-2005, 09:59 PM | #3 |
Chevy Freak
cab mounts
Doc, I'll try to check them out. It may be best for me to cut the cab loose and make sure the holes aren't rotted out. I've seen some pretty nice ones that were rotted around the bushings. I'll get to it later this week. Brian
04-18-2005, 10:00 PM | #4 |
sandblast it and paint it, at least make some mula off of it???? I could'nt scrap anything lol..... but I guess that takes time and space...
04-18-2005, 10:01 PM | #5 |
Thanks!!
Doc
04-18-2005, 10:08 PM | #6 |
I need the last foot or so of the frame in the rear. Mine is a swb, would it be the same? Both sides of mine is a little rusty. If that part is good and you want to cut it, how much plus shipping?
72 C-10 |
04-19-2005, 01:22 AM | #7 |
are the rear bottom shock mounts good?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
04-19-2005, 06:39 AM | #8 |
Is that power steering pump any good and is it for sale? What was it on? How much to ship to 75002.
69 LWB 70 SWB 01 Superduty Diesel 4X4 4door 06 Caddy CTS Last edited by JalopyToGo; 04-19-2005 at 06:57 AM. |
04-19-2005, 07:38 AM | #9 |
Chevy Freak
frame parts
I won't be able to get out into the garage for a few nights, but I'll get everything checked out. The pump was on a 350 that was in it, but it must have been a newer one (I'm assuming with a long water pump) becuase of the newer pump and the alternator wires were moved to the other side. Let me know if you're still interested and I can get a price. Brian
04-19-2005, 07:56 AM | #10 |
Sounds like what I am looking. I converted from a six to a newer 350 with long water pump and need a pump. Let me know what you find.
Thanks Jeff
69 LWB 70 SWB 01 Superduty Diesel 4X4 4door 06 Caddy CTS |
04-19-2005, 08:12 AM | #11 |
Chevy Freak
power steering
Jalopy, if you're just looking for the pump, it would be $25 to your door. Brian
04-19-2005, 12:27 PM | #12 |
Is that including the bracket? If so PM with your address and I will send the money (is a cashiers check OK)?
04-19-2005, 09:21 PM | #13 |
Chevy Freak
parts
Doc, cab mounts are shot. I may getting rid of another one with some nice ones though, so I'll keep you in mind. Ernie, the lower shock mounts are good. $15 to your door. Brian
04-19-2005, 09:32 PM | #14 |
let me make sure i need em....i'll get back to ya..
04-19-2005, 09:36 PM | #15 |
Thanks for checking bud!!
Doc
04-20-2005, 10:08 AM | #16 |
blood type; Retumbo
how much to 57104 for 12" of frame length between the cab mounts? stretching my cab.
thanks, Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
04-20-2005, 10:27 AM | #17 |
Chevy Freak
frame sections
Let me check it out tonight and I'll get back to you first thing tomorrow morning. Brian
04-20-2005, 10:29 AM | #18 |
Keepin an eye out
I would like the front pass. tip back to the first mount.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
04-20-2005, 12:04 PM | #19 |
Chevy Freak
front frame horn
Boraxman, $15 to your door. Brian
04-20-2005, 08:44 PM | #20 |
Chevy Freak
parts
Last part of frame is bad. Mainly because it's got a pile of stuff welded to it. The section between the mounts has some pits. If this is ok, I can cut them out this weekend. Let me know. Brian
04-20-2005, 09:00 PM | #21 |
blood type; Retumbo
any pics of the area in question? I know I am asking a lot, but these pieces would make life easier for me.
04-20-2005, 09:11 PM | #22 |
Chevy Freak
frame pics
Sure. I'll be out of town tomorrow night, but I'll get some Friday. Brian
04-24-2005, 07:45 AM | #23 |
Chevy Freak
parts
68c15, I've been busy this weekend, so I'll try to get some pics tonight. Boraxman, your parts are boxed and will be shipped tomorrow via ups. Brian
04-24-2005, 09:27 PM | #24 |
Working on a Nova.
68C15
I have a 157" wheel base 72 1 ton truck I'm stripping to the ground. The frame is good, but I'm building a short bed truck. This would let you do aproximately a 30" stretch without cutting the frame. It would be one hell of a haul for you but it your interested I should have the thing stripped sometime in late june early july. Let me know! Last edited by GloryHound; 04-24-2005 at 09:29 PM. |
04-24-2005, 09:46 PM | #25 |
Chevy Freak
frame section
68c15, here is a pic of the section. Other side is similar. They will most likely still have a few pits after blasting. $25 for both pieces to your door. Just let me know. I have to get this thing out of my garage this week. Brian
