Professional Grade
Brake switch question
Hey guys!
Does anyone know if someone makes a brake switch for our truck that is normally open? Aka, it lets voltage through while the brake pedal is NOT being touched, but when you press the pedal down, it stops the current? I need one for the electronic cruise setup I am retrofitting into my truck ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Professional Beer Tester
Russell, GM used a switch to disengage the torque convertor lockup when you press the brake. That switch should work like you want.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
What about the brakelight switch for a truck with factory cruise? Actually aren't you describing a normally closed switch? It is closed (lets current pass) until it is moved.
Professional Grade
BeaterC10, its actually the opposite for some reason... if the switch is just sitting on the table, then it will not apply current unless you hit the switch, then it will allow current. So, while it is in the truck, when the pedal is up, it lets current though, but when the pedal is down, it does not. Complete opposite to the stock brake light switches, which allow current when the pedal is down, but not when it is up.
The factory cruise control used the same type of switch as the brakes did, closed when the pedal is down, open when the pedal is up ![]() Shoulda thought about the TCC switch -- That'll work perfectly ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 04-19-2005 at 10:42 PM. |
