Old 04-19-2005, 06:14 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Alignment questions
I am doing bags and drop spindles on the front of my 72 2wd Blazer and was wondering if I need to get longer upper a-arm mounting studs or am I going to be able to move the arm out far enough to get it aligned at ride height. Also is changing these studs a pretty easy job to do. And where would I get them from if I need to change them.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 04-22-2005, 03:03 PM   #2
laid67c10
laid67c10's Avatar
dunno for sure but i think you'd be fine, it shouldnt be too far off with a drop spindle....and aired up to ride height....
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!!
09 - Harley nighttrain on air ride!
laid67c10 is offline   Reply With Quote
Old 04-22-2005, 04:08 PM   #3
Frank_Zeller
Frank_Zeller's Avatar
You need to move the upper a-arms "closer" to the frame when you lower. So no need to get longer bolts.
A little more the 2 inches spring drop is all you can go before you get into front end alignment problems. This is with the stock A arm set up.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 04-22-2005, 07:08 PM   #4
72BLAZERDUDE
I am not sure I understand. Wouldn't " closer " to the frame be opposite of what I want to do. I understand longer bolts which means more shims which means farther from the frame. Having not looked real close at a crossmember out of a truck is it not possible to space out the mounting plate. I know it is riveted to the top of the crossmember but can it be moved.
Old 04-22-2005, 08:48 PM   #5
Slammed67
Progress = 0%
Slammed67's Avatar
Yes, the upper a-arms need to move outward when a truck is lowered to get the camber right.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 04-22-2005, 09:17 PM   #6
SCOTI
SCOTI's Avatar
This is correct for certain applications. However, for GM trucks 64-87, the a-arms usually require spacing outward to regain proper alignment specs after the suspension is lowered.
72Blazerdude, you should be fine w/the stock studs when using drop spindles + bags up front. Your estimated front drop will prob be around 5-6" @ ride height which is common even w/static drops. My 68 & 74 both utilize the stock length studs & both are static dropped 5-6" in the front.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-22-2005, 10:21 PM   #7
Frank_Zeller
This has been my experience with my 69 SWB with 71-72 upper and lower A-arms. 2.5 inch drop spindles plus 2 inch drop springs with all ball joints and bushing replaced.
to get:
-0.25 chamber and 2 degrees caster
There is no shims in the front part of each a-arm front bolt
Two 0.125 shims on passenger side back bolt
Three 0.125 shims on the driver side back bolt
using the gauge like the one in this auction
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Austin-Texas
Old 04-23-2005, 12:19 AM   #8
SCOTI
SCOTI's Avatar
I left out a key word so I edited my original post.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-23-2005, 06:30 AM   #9
Frank_Zeller
I'm going to recheck my chamber and caster today. I bet the difference is in the spindles top ball joint hole location.
Austin-Texas
Old 04-23-2005, 11:35 AM   #10
Slammed67
Progress = 0%
Slammed67's Avatar
True. My '56 Chevy wagon required moving the upper a-arm inward after I cut the coils. However, on those cars the studs face inwards so as you add shims, it pulls the a-arm inward.
Old 04-23-2005, 11:57 AM   #11
SCOTI
SCOTI's Avatar
After reading Frank Z's post I remembered a 66 truck I dropped for my old neighbor (using Turners stepped arms & 1 coil cut from stock springs). It required removal of front shims vs. the typical adding of shims.
I know the avg./typical truck drop will require spacing the arms out, but I guess some are different. Cars do require moving the arms inward because of the mounting orientation of the a-arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
