Old 04-20-2005, 01:36 AM   #1
chevy69er
4x4 Conversion
Ok I know im beating this to death but here i go anyways.Im going to convert my 2wd to a 4wd on my 69 longbed.From what it looks like for the front spring mount all i have to do is replace my core support mount with a 4wd mount and put the spring mount on the bottom side of that.Is this right?How would i go about locating the correct location for the rear spring shackle mount on the frame?Also any info on how to do crossover steering with a 10 bolt front end would be appreciated.Thanks.
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell.
chevy69er is offline   Reply With Quote
Old 04-21-2005, 12:15 AM   #2
earl87gta
earl87gta's Avatar
Your going to have to treat it like a new straight axle convertion mount the front make sure the axle center line is ware you need it take a plum bob hang it from the center of the wheel well as a guid . if it is ware you want it mount the rear spring hanger if its not move the front shackle back our forward.For crossover steering check out ck5.com all you need their.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
