Old 04-20-2005, 09:31 AM   #1
'70_402
'70_402's Avatar
First time manifold question...
I was getting all the surfaces cleaned up and ready for gasgets last night and i decided to put the manifold on there with no gaskets (just to check fit) and i noticed somthing that caught my eye.. (bear with me) where the exaust crossover is in the head there are ports around it.. and oil is in there.. well my manifold only covers the bottom part of those ports.. but the gasket covers them up all the way (i checked)... is this a problem.. i just thought it was wierd... here are a few pics of what i am talking about...
'70_402 is offline   Reply With Quote
Old 04-20-2005, 01:05 PM   #2
Alex Hayley
Set the gaskets AND mainfold on and see if there is a better match of the ports.
Alex Hayley is offline   Reply With Quote
Old 04-20-2005, 01:27 PM   #3
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Whew..don't know about that. Looks like too much exposed area for a gasket to take care of. Unless maybe the gasket set comes with the steel block-out like some small block kits do. Looks too goofy to me though......
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 04-20-2005, 01:53 PM   #4
Alex Hayley
Do you have extra thick head gaskets under the heads right now? Are the bolt holes from the manifold into the head off by the same amount as the ports? Are the heads and manifold original?
Old 04-20-2005, 01:55 PM   #5
Mudder
Mudder's Avatar
That just doesnt look right........
Mudder is offline   Reply With Quote
Old 04-20-2005, 02:13 PM   #6
Chris H
72 C30 Trailer Queen
Chris H's Avatar
In looking at edelbrock's web pages, it looks like the Performer RPM Air-Gap is offered in 2 different part numbers:
7561 for 1975 and earlier oval ports or
7562 for rectangular ports
Could this be the problem? (wrong intake for heads?)
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 04-20-2005, 03:07 PM   #7
'70_402
'70_402's Avatar
I have the part number 7561, and the gaskets will cover it up when put on, but just like mudder said, it just doesn't look right.. i am curious what are those holes...
Here is the combo that i have.. this is basically stock motor..
Heads....#336781
Manifold... #7561
Gaskets...Fel-Pro #1210
Old 04-20-2005, 04:31 PM   #8
arkracing
Weekend Warrior
don't worry about it. mine looked like that too.
once i put the intake gasket on it covered the hole and i don't think that passage goes anywhere...the small hole in the middle does...but the surrounding one doesn't.
scared me too when i put my BBC together and i asked someone who's been a chevy guy for 40years said yeh that's how some of them are..and he was scared the first time he saw it too.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 04-20-2005, 04:33 PM   #9
lngbed71
lngbed71's Avatar
Looks like you have a square port head configuration, and oval port manifold.
Land of the free
Old 04-20-2005, 04:43 PM   #10
'70_402
'70_402's Avatar
nope large oval ports.. #336781 large oval port manifold. #7561
that is what i was thinking also... anyone else ever ran into this...
Old 04-20-2005, 04:50 PM   #11
Alexis
Member since 2000
Alexis's Avatar
have you called there tech line?
Alexis is offline   Reply With Quote
Old 04-20-2005, 05:02 PM   #12
lngbed71
lngbed71's Avatar
Forgot about the large ovals.
Land of the free
Old 04-21-2005, 04:32 PM   #13
cdyblu
cdyblu's Avatar
bb heads
it's normal, nothing to worry about.
cdyblu is offline   Reply With Quote
Old 04-21-2005, 11:46 PM   #14
mr402
That's the way the big block heads are. The opening the arrow point to doesn't go anywhere or do anything except collect debris. Like you said, it was filled with oil. Likely just seepage from the valve cover over the years. Clean it out real well then use a sticky gasket adhesive in that area so the intake gasket will keep it sealed up. Has nothing to do with square vs. oval port.
We've all been through this once.
mr402 is offline   Reply With Quote
