Old 04-20-2005, 06:27 PM   #1
72MARIO
72MARIO's Avatar
Heads Up ! Chevelle Hedders That DO NOT FIT.
I got a set of Hedman Chevelle Shortys part number 68600 1 5/8" primarys to 3" . These do not fit. they are the Ball Flange Style. They hit the motor mounts both sides and the frame rail passengers side. The motor is in the stock V8 location with new motor mounts.
It worked out pretty good because Dad's Swapping a 350 into his 66 Beaumont and he wanted a Hedders for it.
Just Heads up for everyone who is planning on using Chevelle shortys.
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-20-2005, 07:12 PM   #2
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Don't get me wrong, I don't doubt that your's don't fit, but i've seen posts on here with pictures of guys with chevelle 3/4 length (shorties) and they fit well with no problems. Could this be that they have to be run from the 6 cylinder position? I'll try to go back through some of my pics and find the ones that use these. ......Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 04-20-2005, 07:26 PM   #3
72MARIO
72MARIO's Avatar
I know the dynomax with 1 1/2primarys fit but they are to small IMO. And now thta I look at the pitcures they are tight and under hard acceleration I think the would be very close to hitting. I want to get the exhaust system to be able to handle any wild small block this truck could see at some point it it's life.
2005 TAHOE DD
Old 04-20-2005, 07:29 PM   #4
72MARIO
72MARIO's Avatar
The 6 Cyl position might have helped too. Should have done that. Well what ever the search for 1 5/8 to 3" shortys is on. Sandersons only list 1 1/2 also. Anyone using Block huggers ?
2005 TAHOE DD
Old 04-20-2005, 07:59 PM   #5
Goplay2
look at this
http://67-72chevytrucks.com/vboard/s....php3?t=151602
Goplay2 is offline   Reply With Quote
Old 04-20-2005, 08:17 PM   #6
Bowtiefreak
Bowtiefreak's Avatar
Call Sanderson because they do have 1 5/8 primary headers. I have some.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 04-20-2005, 08:34 PM   #7
Alexis
Member since 2000
Alexis's Avatar
it;s the dynomax headers that fit.
Alexis is offline   Reply With Quote
Old 04-20-2005, 11:50 PM   #8
SCOTI
SCOTI's Avatar
FYI . . .... small block headers prob vary from manufacturer to manufacturer, so anythings possible (both good & bad). I've got the Sanderson big block chevelle 3/4 length headers on my truck. They have 1 7/8 primaries & 3 or 3.5" collectors (I can't remember which) & w/the engine sitting on factory 68-71 style big block towers, the fit was fine. I will trim about 3/16" from the pass rail @ the inside/top to avoid clearance issues under engine torque/accelleration, but they're currently installed & there were no interference issues.
I know big blocks & small blocks are different. This was just to inform the masses that there are combos that do fit.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-21-2005, 11:22 AM   #9
Mixup
Chevelle headers don't fit
I have the same headers and they hit the motor mounts to. They sat right on top of them. I cut and rewelded them and now they fit perfect.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 04-21-2005, 05:40 PM   #10
72MARIO
72MARIO's Avatar
I am not angry.
Just want to have the word out that these do not bolt on.
I am looking into the sandersons.
2005 TAHOE DD
Old 04-21-2005, 06:42 PM   #11
jamis
F.A.S.T. president
jamis's Avatar
thats a pain in the butt.......I know how you feel.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 04-21-2005, 06:47 PM   #12
72MARIO
72MARIO's Avatar
It's Cool.
I got them really cheep. I was expecting them not to fit and if they did it would have made my day.
2005 TAHOE DD
Old 04-21-2005, 07:22 PM   #13
jamis
F.A.S.T. president
jamis's Avatar
I ended buy the ones that were supose to fit according to the manufacturer.......they didnt. I think we chatted about this before. I also remember seeing someone post a complaint about the hookers fit as well. So its not just you and me with the bad luck.
