Shortbox wanna-be.
What are the widest tires that can be fit under the wheelwells?
I have seen lots of pics of these trucks in the Pro Street fashion. What I am wondering is what is the largest tires that can be fit between the fender and the frame rail? I do understand that the box would need modifications to the wheel tub area. I am thinking somewhere around 12-14" wide?
Thanks! p.s. pics would be cool also.
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) ![]() |
Back in the sticks
I run 31X10.50X15's with no problem. They've never even offered to rub and thats with a totally stock stance. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Livin' it up.
![]() Join Date: Nov 2001
I've got 32x12.50's on my truck, didnt have any problems front or rear until i switched out my spindles, now it'll rub when i go over a speedbump/dip too quick (20+) sucks but i'll fix it soon. The rears clear no problem from what i can tell, but i'm yet to load 3tons in the sucker so i dunno
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
Member since 2000
285/40/20, good fit, havent driven on it but i think if i turn hard enough it would rub unless i get a rear sway bar, might help .
I've got a set of 295/50R15 which is 14" wide I believe (could be a bit smaller) and have no trouble at all. I havent checked to see if anything wider would fit. These seem to hook up pretty good though and lowering the truck didnt bother them. They tuck under the wheel well nicely.
Slowly getting CRSS...
im puttin 29x15.5x15 on mine, i had tub it and move the e-brake cable clip. w/ 12'' rims i had to have 8'' backspace. ive seen a 70 lwb w/18.5'' he had to do the same stuff but he also had to remove the bump stops and cut away some of the ends of the trailing arms.
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
#7 | |
Shortbox wanna-be.
I'd love to see some pics of that once its got those tires under it!
I used to have 31x18.5x15" Mickey Thompsons on 15x14" wide ralleys w/9.5" backspace, no frame or rear-end mods necessary
(e-brake cables were hooked up but I dont know if they would have worked properly)but did stretch the tubs 9". Although I never actually drove it like that, the wheels & tires fit w/no probs.
My dad's 68
My dads 68 is tubbed w/ a chevelle 12 bolt the tires are mickeys.............i believe that they are 33/??/15.....................
I can post pics as soon as i get home (friday) ..........................Jack ![]()
Jack M. 67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts ****************************** 88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires 4 12 inch Lightning Audios ****************************** 87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ****************************** Dad's truck 68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more ****************************** grand dads truck 68 C-10 stepside fuel inj. 350/700R-4*soon in audi silver* ****************************** 84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames ****************************** S/N=BIGGYTYME@aol.com (hydros) "No fat chics, truck will scrape" |
