Old 04-20-2005, 10:36 PM   #1
67chevytodd
Junior Member
1960 C10
Has anyone put a 60-66 truck on a 72 frame? I have a good donor swb 72 c10 that I thought abou putting a 60 apache body on, was just wondering if anyone has tried this.
Old Chevys never die they are just reborn!
67chevytodd is offline   Reply With Quote
Old 04-20-2005, 11:25 PM   #2
bpmcgee
bpmcgee's Avatar
I've never tried this, but I know the frames LOOK different. I've never taken the time to compare. If you have the two factory manuals, you should be able to compare the measurements, right?
Brian
bpmcgee is offline   Reply With Quote
Old 05-01-2005, 01:43 PM   #3
jchav62
1962 C-10
jchav62's Avatar
I have a 62 that was originally a torsion bar truck like I suppose yours is. Its still has the original frame, but the front end components were switched for that of a 72 or 73. It also has a 72 rearend. So it now has front disc brakes and 5 lug wheels. I would use your donor truck parts to do the same as opposed to using the whole chassis.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
