![]() Join Date: Feb 2000
Help! Front axle problem
Ok, I've got a problem with my '72 Blazer. The passenger side wheel has a clunk to it when you push on it by hand and at about 35mph and 60mph the whole front of the truck tracks from side to side and feels like the wheel is going to fall off. I replaced the front wheel bearings on both sides, the spindle on the passenger side, swapped front and rear wheels on the passenger side, tie rod ends, ball joints all look fine and feel good. It feels like a loose wheel but everything is tight. Anyone have any ideas what could be going on? I need my truck back since it's my daily driver and it's been broken since Monday and everyday after classes I've worked on it tryin to figure this out. Thanks for any help.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Never enough time!!
Did you check the u-bolts and spring mounts? I had a 72 Blazer years ago that the rivits that mounted the spring mount to the frame were broke off, couldn't tell by looking at it, but when we jacked it up by the frame, the mount pulled away. Just a thought...good luck
yeah all that stuff is fine, it is more pronounced when turning right and going stragiht down the road. When you turn left it isn't there.
Saving 1 truck at a time!
Check the tie rod ends. Jack it up on one side with the passenger side wheel off the ground and have someone rock the wheel from side to side while you look it over underneath.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Everything is tight, I took it down to the knuckle, inspected everything, it all checked out. All joints are tight, bolts and nuts are tight, springs are good, perches are fine, you name it, I've checked it and everything is tight and good. I can't find any cracks, no bad bearings, nothing gets hot in the hub. I'm stumped and I've got a lot of my friends stumped too.
