Longhorn, back on the "hydro"
well, the old 383 is takin a good beatin on the 65-6800 shifts on that 6 spd(thrust main). the crank isnt kissin the main webbing yet, & will be running a 400 Turbo(the best that GM did). The auto trannies are a little easier on the engines, & I look for 2 or 3 more seasons of pure he!!! with that 383. the 400 t was a rebuilt trans from a parts truck(driven to the scean of destruction!) it shouldnt work too bad with 3.40 geaRS on a 29" tall tire
http://community.webshots.com/user/hotrodhorn |
#2 | |
Seņor Member
#3 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 04-21-2005 at 11:01 AM. |
#4 | |
Seņor Member
#5 | |
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
LOL! im not sure why I posted here.....I thought I was in engine & drivetrain
Let's see . . ..... carry the one...... divide by the sum total...... add 2 decimal points.... I've got it..... $400* to me since I'm from Tx.
*That of course includes shipping ![]() Seriously, hopefully you can get .50 on the dollar for it. What ratios/splines was it again?
the trans is 1 1/8" x 26 spline input, with a 4.683 front bearing retainer(fits car bell, or 67 & older truck bell) . the ratios are 3.28 2.14 1.57 1.24 1 & .76 for overdrive. I was looking at (hoping for) around .75 on the dollar.....its like anything else tho, once you drive it around the block , the value drops
