Old 04-21-2005, 04:15 PM   #1
cliffsta
Stepsides RULE
cliffsta's Avatar
HVAC high won't work
I remember this getting discussed, but was unable to find it after searching. The high position does not work for the blower motor. When the switch is all the way up, it blows like it is all the way down ("off" even though it still of course blows). Other than the switch maybe being bad, isn't there a plug for the high position that is seperate from the others? Or is it just time for a new switch thingy?
Thanks.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 04-21-2005, 04:49 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
The "HIGH" position for the fan uses a separate power source. Look for a thick wire with a burned connector that runs across the top of the intake or valve cover. That is often the source of the problem.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-21-2005, 10:56 PM   #3
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
There is also a relay which provides power to the blower when set to high. The relay is located in the engine compartment on the outside of the evaporator box. Should also have an inline fuse on the hot lead leading to this relay. Check the connections and the fuse.
NeCrOmAnCeR is offline   Reply With Quote
Old 04-22-2005, 05:12 PM   #4
cliffsta
Stepsides RULE
cliffsta's Avatar
So its one of those big red ones coming out of the firewall up top? Where is the connector that is burnt, or is it the line itself that gets burnt?
I am gonna be bored this weekend and I'd like to sort this out, B/C we all like things to work right And its better to eliminate other problems before trying to find a new switch.
