04-21-2005, 07:44 PM | #1 |
i'm stumped.... truck is bogging down like a cheap gas FORD on a tank of DIESEL!!!!!
ok, i'm stumped!
both Blue_71 and I are stumped.... i dug out my truck for the summer months, and started her up.... did an oil change, and tightened the bolts on the exhaust/donut gasket..... drove her a few times with no problems.... and then.... problem.... in any gear (its a 3-on-the-tree), the truck will bog down if you give it constant gas.... at idle, it appears to run ok - just fine.... i can take off out of the yard in first or reverse - no problem.... if you get it on the road, and if you go past a particular RPM, it just acts as if it were choked with not enough gas.... bogs down seriously so badly that its undrivable.... you can hear it sucking serious air thru the carb.... it wont kill itself, but it wont go anywhere either.... if i got on a hill, i would probably have to give in... thought maybe it was out of gas.... just barely made it to the gas station, filled her up, but the problem still exists.... on the way back, discovered that if you pump on the gas pedal quickly, it gets the power it originally was lacking, and the problem disappears for the small second or two when you pump the pedal... but then the problem continues to exist for a constant gas pedal pressure.... so if you pump the pedal, its jerky from the pumping of the gas, but it acts like it runs fine.... so, here is what i've replaced (these are now brand new parts on the truck).... 0. added full tank of gas to truck (93 octane, for good measure) 1. put on new fuel pump 2. put in new fuel filter 3. fully rebuilt 2bbl carb 4. replaced the HEI module with a new one my truck has a 350 small block, stock cam, stock crank, stock bore, stock pistons, 2bbl carb, HEI ignition, ramshorns manifolds, dual exhaust, no air, no PS, no PB, 3-speed stock tranny, new clutch, stock rearend (3.73), a recently (last fall) replaced drive shaft, tailshaft yoke.... has new oil, new tranny fluid (as of last fall), new antifreeze, and even new washer fluid in a non-functioning washer system..... any ideas? whats wrong? here are some we are contemplating, but still not sure whats up.... A. a filter/sock inside the fuel tank - perhaps part of the sending unit? B. replacing the bottom plate of the carb, which contains the mixture screws? C. the tail-shaft transmission yoke sticking? (it was not a perfect install... lets leave it at that).... D. an engine problem?!?!? the key thing here is the gas..... if you pump the gas, it gets better... but if you increase the gas slowly and constantly, it wont go.... HELP!!!!!! any reponses are greatly appreciated! thanks in advance! ciao! jewels. Last edited by jewels.; 04-24-2005 at 12:56 PM. |
04-21-2005, 07:47 PM | #2 |
Registered Cruiser
Look for vacuum leaks, and make sure your choke isn't sticking,,, g/l
I intend to live forever. So far, so good. |
04-21-2005, 09:07 PM | #3 |
huh ???
My 86 was doing the same thing but I fixed it with a new fuel filter. How do the rubber fuel lines look?
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
04-21-2005, 09:21 PM | #4 |
i'd go for the fuel sock in the tank just pull the sending unit out and have a look , you should get a new o-ring when you reinstall it=they're(o-ring0 are available at any good parts store
04-21-2005, 09:24 PM | #5 |
graphic designer
pulling the sock from the tank might be a good idea. could have gotten some bad juju in there somehow. the other thing is when you rebuilt the carb, i'm sure you replaced the accelerator pump? when my PU was doing this, a fuel filter change fixed it. i WAS using a $50 moroso, hi-zoot gold anodized unit for 3-4 years w/ no problem all of a sudden, it goes hensh!t on me. took it out of the system and replaced the stock Q-jet filter, no more problems. this was after swapping 3 carbs, the dist, and fuel pump(electric). i'm not very quick on easky things i blew thru the filter and it seemed ok
good luck jewels! you too Bloo! if it were in storage for a while, varnished gas could be the problem. i know you put a fresh tank in, but did you check how well the fuel pump is pumping? |
04-21-2005, 10:36 PM | #6 |
Sat all winter? Check the exhaust for a blockage-i.e. mouse nest, dead mouse (or a big rat!) Does it try to spit back thru carb when you step on it?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
04-21-2005, 11:35 PM | #7 |
While you were in the dizzy did you check the centrifugal advance? The HEI’s advance mechanisms have a tendency to get stuck. Feels like you lost over 100 HP when they do that.
04-22-2005, 12:33 AM | #8 |
Hmm - could leaking exhaust donut be caused by plugged exhaust ?? If you have access to a vacumn gauge, put a long hose on it and put it cab when you go for a test drive. If your vacumn gets real low, then your exhaust is plugged. I have seen double wall pipe colapse on the inside while the outer wall looks ok. My 2 cents---
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-22-2005, 03:00 AM | #9 |
Its in the fuel system. I say Accelerator pump. Prob needs a fuel filter too. The one in the carb. Not an inline filter prob. But i cant remember if it has one of those or not.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
04-22-2005, 03:38 AM | #10 | |
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
04-22-2005, 03:46 AM | #11 |
I'm voting accelerator pump..........
04-22-2005, 08:39 AM | #12 |
Jewels & Josh---yo guys, Get a vacuum gauge and check to see what it is telling you. At idle you should be getting about 16-18. (Check out GMC Pauls web site for tips on vac gauge use and timing). If you have a vac leak, you may have decent idle but little to no power due to the lack of proper advance and improper air/gas mix. There are lots of possibilities so you have to kind of eliminate each one but use tools like a timing light---is your timing correct, does it advance when you rev? Is the motor missing or just not taking gas. Could have a ruptured vac advance diaphram. Will it rev at idle or does it bog down out of gear too? How are you spark plug wires---if weak, they will allow spark to jump to ground ---try running it at night in the dark--does it give a light show from spark jumping to ground? My first bet is vacuum leak, then vac advance non function, then accelerator pump, in that order.
Perhaps we should have a contest---guess the problem and win a prize!!!hehehhe |
04-22-2005, 09:02 AM | #13 | |
computer illiterate
72 2wd blazer 72 swb 4x4 |
04-22-2005, 10:10 AM | #14 |
Check all rubber hoses in the fuel line. I have had them collapse when you give it gas. they suck closed when the pump starts sucking harder.they deteriorate on the inside and a flap of inner hose will act like a one way valve. after thirty years + anything is possible. I have seen it happen on just three year gas line hose. just my 02 . and fairly cheap.I would change them first then move on to other things if it doesn,t cure it.
Certifiably crazy person |
04-22-2005, 11:22 AM | #15 | ||||||||||||||||||||||||||||||
it has a manual choke, which is not the problem here Quote:
the rubber line at the engine was replaced last august... the fuel line btwn the fuel pump and the tank might be the problem? Quote:
the fuel filter is brand new as well yes, checked how well the fuel pump is pumping --- the truck runs great at idle and low RPMs in every gear... its only when you give it CONSTANT gas that is just sucks air and doesnt go anywhere... Quote:
no it does NOT spit back at all.... it doesnt not miss, it does not pop, or spit, it just simply acts over choked... it never dies, it just idles fine, but it just goes no where when you give it gas... its like it cannot get above a certain RPM - like it cannot get the gas... Quote:
BTW, Touch_of_Madness, those were all some great suggestions... you have us both talking about all kinds of things we might not have considered before! are you a mechanic? he he (j/k) Quote:
i will re-check the timing tonight.... including advance.... Quote:
[QUOTE=Huck]My first bet is vacuum leak, then vac advance non function, then accelerator pump, in that order. [/HUCK] vacuum leak has been ruled out accelerator pump has been TOTALLY ruled out :ROTF: :LMAO: :LOL: but i am agreeing with vac advance.. Quote:
i wonder if josh and i can come up with a good prize for the winner - let me discuss it with him! Quote:
ok - so here is my "to-do" list for this evening: 1. check vacuum advance (either remove the cone-shaped piece from the system by plugging off the vacuum ports, or use a vacuum gauge to test it while driving) 2. check for bogging when the truck is out of gear at high RPMs 3. check timing & advance settings with the timing light 4. replace all rubber fuel lines (just in case) (esp since its cheap) if all that doesnt work, then we'll start down these roads: 5. pull the bench seat and check the fuel sock 6. check for blocked exhaust - stick wires into all pipes to make sure there are no mice or paper blockages... then perhaps look for a donor set of exhaust to bolt-on temporarily to make sure the mufflers arent clogged... altho - i am really doubting the blocked exhaust thing for one reason --- i have dual exhaust from each manifold all the way to the back bumper --- surely both sides of the exhaust cannot become clogged at the same time, right? the engine doesnt do this on ONE side or the other - it does it equally - would this make any difference? ok - thats enough for now - looks like i have my work cut out for me tonight.... i'll keep yall updated ciao! jewels. Last edited by jewels.; 04-24-2005 at 12:57 PM. |
04-22-2005, 12:46 PM | #16 |
AUSTIN TX
is there a Link to GMC Pauls website
[ (Check out GMC Pauls web site for tips on vac gauge use and timing). If you have a vac leak, you may have decent idle but little to no power due to the lack of proper advance and improper air/gas mix.
would you have a link to his site. Thanks |
04-22-2005, 01:21 PM | #17 |
I didnt understand that you rebuilt the carb AGAIN. I knew you rebuilt it last year. Why would you do it again? If the Accelerator pump bore wasnt totally smooth you could still have the same problem.
04-22-2005, 01:31 PM | #18 |
it seems the problem is still happening so I vote put in a vote for the winshield washer bottle!! good luck!
1972 chev c20 2wd lwb 350v8/th350. (dad's)1970 gmc longstep (9ft commercial bed), 1 ton, 2wd, 350/th400. |
04-22-2005, 01:47 PM | #19 |
Mike
To check the vac advance,if You don't have a vac pump,take the cap and rotor off,and while one of You looks at the inside of the dist the other one suck on the hose that is connected to the vac can.If it moves,and is not leaking it should be alright.If it doesn't move,either the can is ruptured(You would hear it or would not have any resistance when sucking on the hose)or the advance plate is rusted or stuck.It doesn't take a lot of sucking to get it to move.The truck I bought,that sat for 6months,had the advance unit stuck.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires Last edited by smokekiki; 04-22-2005 at 01:48 PM. |
04-22-2005, 01:49 PM | #20 |
I have to say you've done an excellent job describing the symtoms. As a mechanic, I've heard a bunch of 'em, most of which don't help me at all. I'm going to say either clogged exhaust,(even just one side), or fuel starvation, such as the fuel sock, or fuel line. The vacuum gauge should help, or you can just loosen your exhaust at the donut and test drive it. Good luck & let us know what you find.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
04-22-2005, 01:59 PM | #21 |
When you do the vacuum test, hook up the gage and as said, you should somewhere between around 18-21 depending on altitude. The needle should not move. Give it a strong shot of gas, pull the throttle wide open, and your needle should smoothly move to somewhere around 26-30 and then drop back to idle vacuum. My thought (other than the fuel sock, which could be your culprit) is a bad coil. Mine went bad. Killed my HEI. Truck had the same symtoms as yours. Hope I'm not reposting info, there was tons to read.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-22-2005, 04:23 PM | #22 |
A few years ago I had the same sort of problem with my truck, after changing this and replacing that we found out it was the fuel pump.
I put on a clear fuel filter and was watching the gas flow through it and noticed the filter would fill up and then get almost empty and the engine would start stalling. Another thing to think about is the gas tank vent along with all the above suggestions including the washer bottle
Currently helping a Friend build a 71 Custom Camper into his dream truck Guess that makes me the Middle man since he asks questions and I search for the answers |
04-22-2005, 04:49 PM | #23 |
Jewel's & Josh, I would attack as follows:
1- With a timing light and the engine ideling, rev engine and see if the timing changes big time---you should have centrifical and then vacuum advance moving your timing. 2- If not much advance, pull dist cap and rotor and look at the two half moon weights with springs--make sure they are free and the plate they are attached to, moves to turn the rotor. Then as suggested before, use some vacuum---either a pump or suck on the end of the vacuum advance hose from the carb--to see if the dist plate moves as the diaphram within the canister for the vac advance moves the dist plate to change timing. 3 - Next I would pull the fuel sending unit from the gas tank to check the sock. While there, I would also pull the line off the fuel pump and using some air pressure, blow out the fuel line and watch to see what comes out--not to close!! 4 - then loosen the manifold to exhaust pipe connection to see if you have too much back pressure from nests within the muffelers. Question---when you changed the dist to HEI, did you use heavier wire from your fuse box bringing 12V to the dist??? You need to step up aoubt 2 gauges of wire to get adequate juice to the HEI dist verse the point dist. Let us know what you find tonight~~~~~~ |
04-22-2005, 05:36 PM | #24 | |
i'll let you know what we find out jewels. Last edited by jewels.; 04-24-2005 at 12:58 PM. |
04-22-2005, 06:29 PM | #25 |
I had the same problem with a newer truck, changed nearly everything and finally out of desperation cut the catalytic convertor out and presto ran like a new truck, replaced the cat with a new one and haven't had a moment's trouble since. So needless to say my vote is with the exhaust system.
