86 s10 blazer keeps blowing ECM B fuse
Every once in a while when I start the Blazer I turn the key and it runs for about 2 seconds then dies, then will not start back up, due to the 10amp fuse marked ECM B. I also get no trouble code from the diagnostic mode.
This seems to happen randomly once a week or so out of nowhere. I have a 1986 2.8L V6 S10 Blazer. If anyone has any idea how i can narrow down the problem, there are tons of sensors and relays and crap. Could it be the oil pressure sensor? It also has TBI and a manual trans, 4x4. thanx |
You need a new fuel pump...Ecm b fuse is tied into the fuel pump relay circuit... That should do it...S-10 wiring are a little funny to fix...I have run into this before..I have 6 blazers here for parts..
wouldnt the thing not run right if it were the fuel pump though?
If you look at a wiring diagram,the ecm b fuse controls the fuel pump and the injectors. Thinking on it a while ,it may be in your distibutor too.. The fuel pump and pickup coil in the dist,wont set a code...Did you change the oil pressure switch?
Does your radio work fine? I know this sounds weird but check all the other fuses,if the radio fuse is blown too,change that fuse out.. It will backfeed into the ecn b fuse...Trying to help. Last edited by bisquik65; 04-24-2005 at 06:18 PM. |
my radio and stuff works fine. I am a little confused about the oil pressure switch, or where it is. On the drivers side of the block just under the oil filter there are 2 switches/sensors. One has 2 connection posts, the other has three. I assume one is the oil pressure swich, but witch one, and what is the other thing?, fuel pump/pressure regulator?
The 3 wire one is for the fuel pump. If your motor loses oil pressure it will shut the pump down,you may want to check oil pressure too.
it is the oil pressure switch, if i unplug it everything works fine, except for the gauge anyway....
OK glad you found it,Later,Erick
thanks for the help, if u are parting out some s10 blazers maybe i get some parts from ya....
Welcome to the board!!!Post your location so it will help you find stuff closer to you..
guess im kinda far here in Reno Nevada
