Old 04-22-2005, 02:15 PM   #1
chip46wis
Disk swap 85-69
Ok--I am swapping disk from a 85 1/2 2wheel to my 69 2 wheel that had drums.I see a huge difference in the size of the lower A-frames and upon closer inspection the (control?) tubes from the 85 are not real good shape.Can I use the 69 A frames with the 85 spindle and new ball joints for the 85 type? I see differences in the upper a arm where it mounts to the bolts in the frame as in the factory spacer is completly different---SO i want to keep it simple with the 69 a frames and the 85 spindle---HELP please
chip46wis is offline   Reply With Quote
Old 04-22-2005, 02:18 PM   #2
Orange70chevy
Orange70chevy's Avatar
Just change your ball joint to the 85 style and everything will bolt right up
Orange70chevy is offline   Reply With Quote
Old 04-22-2005, 02:42 PM   #3
chip46wis
Thank you so much orange70chevy i am going right now to pick up the 85 ball joints-----lower and upper-AGAIN-THANK YOU ALL-fantastic group here-before I leave I am making a contribution to support this board----very well deserved and appreciated
Old 04-22-2005, 07:58 PM   #4
69 longhorn
you will need the later tierod assys(innners,outers, & sleeves), & the centerlink also. You may also find that differences in steering stops will shorten your turning radius.....no biggie tho, a little session with a grinder will take care of that L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-23-2005, 02:03 AM   #5
chip46wis
Thank you longhorn,I am planning to use the 85 steering linkage and steering box also. Thank you both very much.
