Old 04-22-2005, 10:23 PM   #1
gregbr
Senoir Member
gregbr's Avatar
WTB: 4wd frame piece where p/s box mounts
Anybody got a trashed 4wd frame for parts? I would like to get the front drivers rail where the p/s box bolts on so I can add p/s to my 67 4wd. Shipping to 29730. Thanks, Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 04-22-2005, 11:00 PM   #2
4bynut
4bynut's Avatar
I might have one for you. How much past each side of the power steering gearbox do you want. I'll look Sunday for you. Thank's Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 04-22-2005, 11:22 PM   #3
gregbr
Senoir Member
gregbr's Avatar
I'd like the bumper end complete, just cut it 4 inches or so past the mounting holes toward the firewall.....making it about 2 feet long approx. Thanks
Old 04-25-2005, 02:57 PM   #4
4bynut
4bynut's Avatar
Hi Greg, checked out the frame I have today and I don't think the section you need is usable. It looks tweeked, like the truck had been in a bad accident. If your frame is good, I seen another option for reenforcing it at the steering gear box that would also give you the dimple where it bolts on. You could just tack weld a shim between the 2 where your's isn't dimpled. Here's a pic I saved of that option. Jason
Old 04-25-2005, 08:38 PM   #5
JimKshortstep4x4
Talking
I have a good section where the steering box mounts. The nose is there but has been used for a plow and the spring perch is no good.
If you can use the section for the box, you can have it for the shipping costs.
Jim
Old 04-25-2005, 09:57 PM   #6
gregbr
Senoir Member
gregbr's Avatar
Thanks for the info & help Jason.
Sounds good Jim, Let me know about the shipping to 29730. Take paypal? Greg
Old 04-26-2005, 01:22 PM   #7
JimKshortstep4x4
Talking
How about if I cut the section about 3" beyond the bolt holes on both ends?
Will that work or do you want more?
I hate to ship you extra weight.
I don't have Paypal, sorry!
Jim
PS: Here is a pic . Cut at the chalk marks ok?
Old 04-26-2005, 08:41 PM   #8
gregbr
Senoir Member
gregbr's Avatar
Between the marks will be fine. Send me you address when you tell me how much $$$. Thanks, Greg
Old 04-27-2005, 07:28 AM   #9
JimKshortstep4x4
Talking
PM sent.
Jim
