04-22-2005, 11:35 PM | #1 |
Certified Truck Nut
is this rare at all?
i have an 82 GMC Sierra Classic 1500, Factory air, tilt, cruise, ps, pdl. it also has the 4 headlight front end, which most of the local chevy truck guys say is kinda odd. is this less common setup, or just par for the course? oh it also was the electronic spark control (ESC) badges on it.
i can post the option tag if someone is curious. thanks later Dan
1982 GMC Sierra Classic 1500 Longbed 350, TH350, 3.73 10 bolt soon to be slammed |
04-22-2005, 11:45 PM | #2 |
sounds pretty run of the mill. 4 headlights were standard 82-87
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
04-23-2005, 12:46 AM | #3 |
FUJIMO
Even an old ford guy would tell you that 4 headlights on a GMC is the norm. All the other options are also pretty much run of the mill stuff. With a few exceptions, most GMC trucks had four headlights and chevy normally ran just two untill the 1988 style truck hit the scene.
IF IT DON'T GO--CHROME IT!! I dont mind confusion, I create it! |
04-23-2005, 12:50 AM | #4 | |
04-23-2005, 01:12 AM | #5 | |
FUJIMO
IF IT DON'T GO--CHROME IT!! I dont mind confusion, I create it! Last edited by draino76; 04-23-2005 at 01:34 AM. |
04-23-2005, 01:54 AM | #6 |
Let's see some Pictures!!!!
1985 Chevrolet C-30 454 1-TON Dooley 1969 CHEVROLET CST-10 PICK-UP Good memories 1999 Chevrolet Z71 Ext. cab 5.7L Good Memories With a quart of oil, and a gallon of gas, she won't let no other car pass!!!. & FOREVER |
04-23-2005, 02:47 AM | #7 |
all 81 plus customs/scottsdales have two headlights.
my 84 scottsdale = two headlights
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
04-23-2005, 08:14 AM | #8 |
Tonawanda 454
i think the 81+ scotsdales mostly had 2 headlights even into the 91 burbs but the silverado and better packages went with 4 headlights...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
04-23-2005, 09:11 AM | #9 |
81+ Silverados had 4 headlights, everything else got 2.
04-23-2005, 01:17 PM | #10 |
cool, for some reason i was thinking all the 81 up were 4
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's Last edited by low 84; 04-23-2005 at 01:19 PM. |
04-23-2005, 01:29 PM | #11 |
Right turn Clyde
But couldnt you have a custom delux and order the 4 headlight option?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
04-23-2005, 01:47 PM | #12 |
no, it was part of the Silverado trim package.
04-23-2005, 01:48 PM | #13 | |
Web Wheeler
I often use this brochures link when a question arises about OE equipment & options. http://brochures.slosh.com/
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
04-25-2005, 10:58 AM | #14 |
Shadetree Mechanic
Yes you could get the 4 headlights as an option
You could order just about any option you wanted with a few exceptions.
I ordered a Scottsdale because I didn't want carpet or power windows and locks, but I have just about every other option you could get on the Silverado including 4 headlights and deluxe cloth seats.
Dave M. (Hacksaw) 86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance 89 GMC S-15 Extended Cab 4x4, 4.3L, FI 98 K1500 Xcab, 5.7L, 3.43 Gov-Lok |
04-25-2005, 11:40 AM | #15 |
www.73-87chevytrucks.com
4 headlight was standard on the Silverado from 81-91. 2 headlight was standard on all other trim packages. 4 headlight were optional for all other packages except for a base trim truck and this being GM, I wouldn't doubt there are not some of them out there.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
04-25-2005, 11:55 AM | #16 |
Tonawanda 454
ok a curiosity of mine... are the mounts the same for say the dual and single headlight setups for a given year? for example if i wanted to go w/ the dual headlight on my 91 burb or even the single long lighting from a 92, would the mounts match up?
a second curiosity has anyone tried to setup a 82-91 with the grill/etc from a 73-80? (something like pic below)
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- Last edited by screwballl; 04-25-2005 at 12:10 PM. |
04-25-2005, 12:20 PM | #17 |
Core supports are specific to headlight versions.
To put a 73-80 on a 81-91, you need the complete front clip.
04-25-2005, 05:22 PM | #18 |
notice the leading edge of the hood doesnt match up with the grille trim. on a regular 73-80 core support, it follows the line of the leading edge of the hood.
04-25-2005, 11:05 PM | #19 |
Tonawanda 454
doing this would also mean get a hood from a smiliar year truck since they have the protruded front...
but the question i was wondering was would it be easy and possible to switch the scotsdale single headlight setup to the silverado dual headlight setup say both from 91 burbs??? or did they keep the mounts specific based on the headlights only?
04-25-2005, 11:38 PM | #20 |
As I said above the core support is specific to the headlight versions. If you want to go from singe to dual headlights you have to swap core supports.
04-26-2005, 12:24 AM | #21 | |
