06-11-2002, 11:40 AM | #1 |
4" lift pitman arm
I PURCHASED A 4" LIFT RECENTLY. I NOW NEED A DROP PITMAN OR WHATEVER ELSE SHOCKS ETC TO COMPLETE IT. I KNOW I'LL PROBABLY GET THE SHOCKS THROUGH 4X4 WHOLESALERS BUT WHERE SHOULD I GET THAT ARM OR DOES ANYONE HAVE ONE FOR SALE?? MY BUDDY SAID HE GOT HIS FROM 4X4 WHOLESALE FOR AROUND $55.
72 CHEYENNE 3/4 TON 4X4...14 bolt full float rear.4.10 gear and 350/350/np205 has a little needs a lot! |
06-11-2002, 12:04 PM | #2 |
same
get it when u get your shocks. they are all priced about the same.
06-11-2002, 12:30 PM | #3 |
Post Whore
I got my adjustable drop drag link made by Skyjacker from www.offroaddesign.com It's not on their website, so you would have to call them. Seems it was around $90-100. There aren't any dropped pitman arms that fit the old closed knuckle Dana 44 that was used on my 69 - that's why I had to used the drop drag link.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
06-11-2002, 11:35 PM | #4 |
I got an Explorer Pro Comp from 4 wheel parts wholesalers. I had a $20 coupon so it only cost $35 bucks out the door! I ran my truck for over 10 years without the arm, but when I did the new drag link and AGR rockcrawler box and pump I figured what the heck and went and added the arm. FYI, all pitman arms are the same for Dana 44s and 8.5" 10 bolts. The one for our trucks has been discontinued so I went with one from a 1992 3/4 ton Suburban (last of the straight axles)
