Old 04-23-2005, 01:31 PM   #1
mudgutsandglory
Certified Truck Nut
mudgutsandglory's Avatar
no start, HELP!!
hey guys ive been working like mad to get the new motor in the '82 GMC fired, and after all the thrashing i have a no start, i dont even get a click at the solenoid, so...i ran to the parts store and got another starter, same mess...
i think im missing a wire, but i cant find it!
here is how i have it hooked
there are 3 terminals on the starter
the first terminal,(from left looking from front of truck) is marked R, and i have nothing on it...
the second terminal is the main and i have the main hot battery lead and another ring terminal that has two like 10 gauge wires hooke to it on that terminal...
the 3rd terminal is marked S, and i have a single wire with a small terminal hooked to it...
for some reason it wont crank, i think im missing a wire, and im worried like crazy
please help
later
Dan
1982 GMC Sierra Classic 1500 Longbed
350, TH350, 3.73 10 bolt
soon to be slammed
mudgutsandglory is offline   Reply With Quote
Old 04-23-2005, 01:42 PM   #2
badone07
Project 2 Resume
badone07's Avatar
check neutral safety switch (auto) or clutch switch (manual) hooked up?
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
Old 04-23-2005, 01:57 PM   #3
mudgutsandglory
Certified Truck Nut
where is the neutral safety switch at??? its an 82 with an auto.
thanks
later
Dan
soon to be slammed
Old 04-23-2005, 02:11 PM   #4
badone07
Project 2 Resume
badone07's Avatar
thanks
later
Dan
steering column.
here's a schematic to also look at.http://www.chuckschevytruckpages.com...oodwiring.html
John
Old 04-23-2005, 03:13 PM   #5
mudgutsandglory
Certified Truck Nut
i still cant get it to start, this sucks!!
anyone got a better underhood wiring diagram?? or for that matter anyone willing to take some underhood pics to show me whats what??
thanks
Dan
soon to be slammed
Old 04-23-2005, 04:04 PM   #6
78c20
If you have access to the book ' How to build Hot rod trucks' by jim clark look on page 107. there is a very clear diagram. Basically the larger of the three terminals should be connected to battery and, via gauge, Alternator. second terminal to ignition, third terminal to coil.
hope this helps.
78c20 is offline   Reply With Quote
Old 04-23-2005, 04:59 PM   #7
badone07
Project 2 Resume
badone07's Avatar
here's another diagram. did you try a remote starter switch to determine if it's the starter itself or rest of ignition system? then back track to the ignition switch? check the fuseable links? battery charged? check block on firewall to the left of wiper motor, for bad contacts or corrosion (in first diagram above)? if it started before motor pull and reinstall, should start now. I don't have any pics of a chevy starter wired up presently. even my pu's starter is blocked by the headers. maybe someone else does, but your's should be correct anyway by description.
John
Old 04-24-2005, 09:29 PM   #8
77C10step
Follow the voltage trail
Is there power to other areas like dome lights? If not, I would check the two connections at the junction block on the fire wall. Mine is a little older, but I had the same problem a few days ago and after chasing voltage from the battery to the starter to the fuse back on the fire wall, I found a loose connection on the junction box. The fuseable links were ok. The wire was not tightly connected. Tightened it up and then had power. Good luck!
77C10step is offline   Reply With Quote
