Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 04-23-2005, 01:33 PM   #1
Chevy Muscle
< 69 Blazer
Chevy Muscle's Avatar
Wanted: Fresh SBC in/around DFW
I'm needing to replace the 350 in my blazer since it's smoking and using oil.
I'm wanting a freshly rebuilt small block engine, or one with only a few thousand miles on it. 350 / 383 / 400 ci. I'm not wanting anything smaller. Around 9-9.5:1 compression would be nice.
Let me know if you have one for sale. Thanks,
Justin
Chevy Muscle is offline   Reply With Quote
Old 04-25-2005, 09:28 AM   #2
djohnson
I have one that I might sell. It is a 350 that I purchased new from GM for my Blazer project about 5 years ago. I added an Edelbrock performer cam, timing chain, and intake. The Blazer is still not drivable, so it has almost 0 miles on it. I start it every few weeks to let it run for a while. I am not sure what a fair price would be (I have somewhere around $1700 invested). Let me know if you are interested and we will see if we can work out a price.
djohnson is offline   Reply With Quote
Old 04-25-2005, 09:59 AM   #3
Chevy Muscle
< 69 Blazer
Yeah, I might be interested. I have a few questions:
Which GM engine was it? (260hp, 290hp, 330hp....etc...)
What is the compression ratio?
What heads are on it?
What are the cam specs?
2-piece rear main seal?
If you want, PM me your number. I'm right down the road from you in Murphy.
Old 04-25-2005, 11:09 AM   #4
djohnson
It's GM part number 10067353.
Horsepower¹: 249 HP @ 5,000 RPM
Torque¹: 304 FT/LBS @ 3,500 RPM
Redline: 5,200 RPM
Comp. Ratio: 8.50:1
Heads: Cast Iron, 72 cc Valves: 1.940” I, 1.500” E
Block: 4 Bolt Main, 2 Piece Rear Main Seal, 4.000” Bore
Crankshaft: Cast Iron Nodular, 3.480” Stroke
Spark Plug: R44TS, Gap @ .035 For Points Distributor or .045 For HEI Distributor
Ignition Timing: For most applications it should be 10 to 12 BTDC°, Total timing, which includes base setting plus centrifugal advance, should not exceed 36°.
The cam is an Edelbrock Performer part number 2102 (specs can be found at www.edelbrock.com)
I will pm you with my number.
Old 04-25-2005, 07:07 PM   #5
Gray Ghost
Gray Ghost's Avatar
Call Loden's Machine shop and ask for Lester...350/300hp/375ft.lbs $1100 out the door. Tell Lester I sent ya. give him a week or so to put it together. PM me if you want the number.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 04-25-2005, 09:44 PM   #6
Chevy Muscle
< 69 Blazer
Thanks Kelly, yeah, I want the number if that was for a long block.
I'll PM you on the other board.
