Old 04-23-2005, 03:35 PM   #1
78c20
Exclamation Help! Isolator?
I have a 1978 Chevrolet C20 here in the United Kingdom that is probably ex-USAF.
I have recently imported ( from the USA ) a 350cid small-block with a few performance goodies fitted. Now the problem is, located on the firewall is a small ( approx 3x5inches ) finned metal box marked battery-isolator. The box has three terminals on it. Are these three terminals ie 1 for feed in, 1 for return to charge batteries ( truck has two ) and one to the lamp in the cab?
Can anyone tell me what this thing is/does and do I need it?
How should this be wired into the wiring-schematic?
( original engine was a straight-six if this helps )
Kindest Regards from the UK.
78c20 is offline   Reply With Quote
Old 04-23-2005, 05:22 PM   #2
Russell
Professional Grade
Russell's Avatar
That thing is for your dual battery setup. If I remember correct, the way they are to be wired up is that the one wire comes from the alternator, and the other two posts go to either battery's positive post.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-24-2005, 09:47 PM   #3
bagged74
its just $$$$$
bagged74's Avatar
that is correct.
that thing is basically just a big diode, to keep the batteries isolated from one another, but allow them both to charge.
bagged74 is offline   Reply With Quote
