04-23-2005, 04:26 PM | #1 |
Gettin It One Pice At A Time
asap
I will be replaceing my Lock Cylinder today and I need to be sure that this (http://www.partsamerica.com/ProductD...pe=521&ptset=A http://www.partsamerica.com/ProductG...name=Lockworks ) will work. it says on the buyers guide (2nd one) that it will but I want to make sure. thank you for your fast replys! matt
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
04-23-2005, 04:35 PM | #2 |
Looks like the right one to me.
Support your local search and rescue team.... GET LOST! Originally Posted by DURRTY if some is good more is better too much ought to be enough........ |
04-23-2005, 04:43 PM | #3 |
do you know of any tips I should know befor I pull the wheel?
04-23-2005, 05:19 PM | #4 |
Professional Grade
Just keep an eye on everything, and don't forget where stuff goes, hehe
Actually, removing the lock cylinder is a very easy procedure. Just make sure that you set yourself up with a good locking plate compressor, and wheel puller!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
04-24-2005, 01:05 AM | #5 |
As Russell said, steering wheel puller and a lock plate compressor, they make life a lot easier!
The Lock cylinder is a really easy fix, theres one screw holding it, and i think it needs to be in either the unlocked or run position to be removed.
Anthony 07 Tahoe LT 70 Chevelle 450HP 383-TH400 77 GMC Royal Sierra~Resto in progress~ |
