Old 04-23-2005, 06:37 PM   #1
72gmcshorty
72gmcshorty's Avatar
Horn problem
Today my horn decided to blare non stop. I don't know why but just as I pulled into a parking stall, my horn cap popped off (after market wheel) and the horn started blaring non stop. I pulled the wire off the connector in the steering wheel itself so it would stop. I don't know what to check here. Any idea?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 04-23-2005, 07:59 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
It grounded out somewhere, check everything from the relay up to the horn button. check the wire through the coloumn and see if it got pierced, also check the aftermarket cap kit, if it came loose and shifted thats all it takes....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 04-23-2005, 08:28 PM   #3
Martin64
Martin64's Avatar
Mine did the same thing. It turned out to be the relay. If you find that it is the relay, in your case, then be sure to disconnect the relay or it will drain your battery. At first I didn't relate the 2 (in my mind) and ended up buying a new battery charger......after I bought a new battery.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 04-23-2005, 09:02 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you say aftermarket wheel...you talkin Grant GT with the little plastic horn button?
The button popped off, and then the horn sounded off, right?
I'll bet that the wire that goes to your horn button was touching the steering wheel it's self, grounding it, causing it to turn on the horn.
As a matter of fact, since you removed this exact same wire and it stopped the horn, it has to be that wire.
Old 04-23-2005, 10:55 PM   #5
SB_in_SC
'68 C10 SWB/FS 396/TH400
SB_in_SC's Avatar
My '72 C10 decided to do the same thing at 2a.m. one morning, many years ago. It was the relay. But like Longhorn said, if disconnecting the wire at the wheel worked, its probably the cheapo button on that steering wheel.
'68 Custom/10 w/396/TH400 matching #'s
'00 C3500 Dually 454 Crew Cab
'99 Chevy Tracker 4x4 (1 tuff little muther!)
SB_in_SC is offline   Reply With Quote
Old 04-28-2005, 04:55 PM   #6
Lorrai
I did the same thing martin 64.. did anyone ever get the horn to work properly? I am still running with mine disconnected. I have half a mind to put the old, big steering wheel back on. Any suggestions?
Lorrai is offline   Reply With Quote
Old 04-28-2005, 08:50 PM   #7
Longhorn Man
72gmcshorty, did you ger your horn workin?
Lorrai, is your relay screwed like martin64, or is it the horn button, you indicate both.
