04-23-2005, 06:39 PM | #1 |
Carb problem
I have an Edelbrock carb and when I punch the throttle the truck will cough/ bog down/ hesitate for a second before kicking in. I can push the accelrator slowly and it won't do this. It's only when I punch it. Any ideas?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
04-23-2005, 06:55 PM | #2 |
There is a accelerator pump linkage. There are 3 holes out of the box it's in the middle try moving it up to the top hole. That will be giving the motor a bigger squirt. Do you have the owners manual ? If so there is alot of great info to dial in that carb.
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
