Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-23-2005, 11:19 PM   #1
bigblockguy
'62 half ton short frame for sale
I bought this '62 shortbed frame for a hot rod project and ended up finding a very strong '63 GMC frame that I plan to use instead. The GMC crossmember will be bolted to this frame and it's set up for a V-8. Original rear end, 6-bolt lugs. One coil spring is broken, but the truck was never wrecked and there is nothing more than surface rust anywhere. I'm in Lubbock, TX. I'd like to get $200 for the frame and have a sweet set of aluminum wheels for it for an additional $100. Email me at 81vette4speed@cox.net if you're interested.
bigblockguy is offline   Reply With Quote
Old 04-23-2005, 11:21 PM   #2
bigblockguy
I bought this '62 shortbed frame for a hot rod project and ended up finding a very strong '63 GMC frame that I plan to use instead. The GMC front crossmember will be bolted to this frame and it's set up for a V-8. Original rear end, 6-bolt lugs. One coil spring is broken, but the truck was never wrecked and there is nothing more than surface rust anywhere. I'm in Lubbock, TX. I'd like to get $200 for the frame and have a nice set of aluminum wheels for it for an additional $100. Email me at 81vette4speed@cox.net if you're interested. Wheelbase and widths are the same as '55 - '59 and you can either run this IFS or bolt on one from a '73 - '87 - it's a direct bolt up. All you need is cab/bed/core support mounts and you're ready to go.
Old 07-24-2005, 05:39 AM   #3
65_Chevy
do u have any pics plz send them to tie_commander@msn.com
65_Chevy is offline   Reply With Quote
