A couple 350 questions
Where is the fuel pump located on your 350? And also do any of you have pics of the power steering set up on your truck?
I just wanna make sure this engine from a Chevy van is gonna work out. Thanks
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Fuel pump on my toy is front of engine, left of water pump.
Just follow gas line into carb, maybe 2 feet or so. No pics...sorry. HTH...don t. .... |
![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
fuel pump is on the passenger side, I recently swapped out the power steering unit in mine from a 71 unit to a unit off of an 84 GMC jimmy. I had to fabricate(cut off part) one of the mounts. But it works much better because the belt adjustment was much easier to do. My former set up was mounted very low and the belt was very hard to tighten. I had to take the valve body out of the old pump and put it in the 84 pump so I could use the same pressure hose. I can take some pictures for you this weekend if you need me to.
Thanks guys. The fuel pump is right where I thought it would be, just gotta get one now. And the power steering pump seems a bit low on this engine but only because it's from an 85 van. I think it will work just fine.
